TODRZ Posted January 22, 2024 Share Posted January 22, 2024 Hi, i have had a RZ Supra in shed storage for about 3yrs. Recently I pulled the cover off for a bit of TLC and noticed i had a rat problem. I have been over the whole car and located 2 wire harnesses they had a chew on. I have re joined and soldered the damaged areas(they are all checked and good for resistance and continuity). My problem is now the ABS light is on and the Main caution light in the middle of gauge. I pulled the Abs fault Code using the Tc-E1 method short pin removed and getting 1 code: DTC 23 I have checked and tested all relays, fuses, and wire continuity from everywhere to everywhere. ALL GOOD. I have followed all the diagnostic processes in the manuals with no luck of finding this issue. All and Any Ideas appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
Iky Posted January 24, 2024 Share Posted January 24, 2024 I've had it where I've unplugged the sensor/ECU but after a short drive it turns off itself. Quote Link to comment Share on other sites More sharing options...
tomgeer Posted January 25, 2024 Share Posted January 25, 2024 Couldn’t be something as simple as an ABS sensor faulty could it? Quote Link to comment Share on other sites More sharing options...
tomgeer Posted January 25, 2024 Share Posted January 25, 2024 Also as above, try disconnecting the battery for 10 mins or so to reset the ECU if you haven’t already done so. Quote Link to comment Share on other sites More sharing options...
