SIMON LC Posted August 27, 2023 Share Posted August 27, 2023 Ok. Currently N/A and going Turbo. Decided to get GE VVTI to turbo. I understand a Lexus GS 300 VVTI engine loom is for ECU location in engine bay. Has anybody encountered this and what is the best way round it?have loom made up. Modify a GE loom or modify a Lexus VVTI loom? Quote Link to comment Share on other sites More sharing options...
AC93 Posted August 27, 2023 Share Posted August 27, 2023 I had my existing Supra loom modified by SRD to include the VVTi bits and to run the other sensors for the build Quote Link to comment Share on other sites More sharing options...
SIMON LC Posted August 27, 2023 Author Share Posted August 27, 2023 So it can be modified? How does it work with the main ECU block Connector? Quote Link to comment Share on other sites More sharing options...
AC93 Posted August 30, 2023 Share Posted August 30, 2023 Well I went turbo and standalone at the same time, so SRD supplied and fitted my Link ECU which would have been a plug and play? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 5, 2023 Share Posted September 5, 2023 You can use non VVti engine loom with whatever standalone ECU of your choice then add the VVti wiring in an auxiliary loom and connect to ECU that way Quote Link to comment Share on other sites More sharing options...
