Guigsy Posted August 17, 2023 Share Posted August 17, 2023 (edited) ITEM SOLD Syvecs S6gp - Stand Alone ECU £1000 This is a Syvecs S6gp ecu that i purchased for my supra build some time ago but unfortunately now cant use. It was an early s6gp unit without CANbus that is in a newer s7 case and with the newer s7 style superseal plugs. Unit is in working order and good condition appart from not having the canbus function. Its not new, but i dont believe its ever been used. The serial number for this unit is 0523 However for full disclosure (and the reason i cant use this unit). It was sold to me 2nd hand as a s7i some time ago but i found out when fitting that it had been converted from an early s6gp without CANbus to a s7i, and so was running a s7i board but without the CANbus functionality (Which i needed for my particular build.) However iv since found out that a s6 cant be "converted" to a s7. Syvecs have said the serial number 0523 - "its a non can bus s6gp with super seal connectors" Why its in the new style case with the different connectors than the s6gp came with origoanly? i dont know. It looks like a s7i. But the internal motherboard is (as far as i know) probably not a s7i, its a s6gp. The above shouldnt make any difference to the useage of the ecu if you dont need to use canbus (check with your tuner. i dont know if you will need it or not). And you should be able to use a s7i plug and play harness just fine, which might even make things easier as they are still available new. I want to use a canbus based guage which i have already purchased and had all my other guages removed. So its easier for me to swap out for a different model with CANbus, Normal more traditional guages will still work fine with this unit. This was all confirmed to me by Paul at Whifbitz along with some help from Lee at SRD and a few others in the supra comunity. So thank you to them for unraveling this bit of mystery. PLEASE NOTE - This is a bare ECU, No cables, harness or sensors. Item will be shipped by Garage whifbitz in South Wales, UK, not myself as my car is currently there having work completed. Again - THE CANBUS OUTPUT IS NOT PRESENT ON THIS UNIT. Item is sold as is and fully described above. If you NEED the canbus for whatever reason. This item isnt for you. Edited September 25, 2023 by Guigsy extra info, model number change, pictures (see edit history) Link to comment Share on other sites More sharing options...
Guigsy Posted September 12, 2023 Author Share Posted September 12, 2023 Realised i hadnt updated the post after finding out this is more than likely a s6gp not a s7i. Lowered the price a good chunk. and added some pictures. Link to comment Share on other sites More sharing options...
Guigsy Posted September 19, 2023 Author Share Posted September 19, 2023 still got this. if someone wants to make me a decent offer ill considder it. Link to comment Share on other sites More sharing options...
