Supraman1511 Posted August 4, 2023 Share Posted August 4, 2023 Apologies in advance if this is in the wrong section. I recently did the heater matrix swap and moved my map sensor to get access to the water pipes. I took a pic of where it was but it's not very clear on what the brackets should look like. Is it 3 brackets? I have the map sensor still on it's part of the bracket and the earth cable still attached to its own bracket, these slot together to line up the bolt hole. There's 2 bolt holes on the firewall so am I being thick or am I missing a third section of the bracket? Link to comment Share on other sites More sharing options...
