SmuleH Posted July 20, 2023 Share Posted July 20, 2023 Bought a pressure plate and flywheel together with an engine that have been laying in the corner of a workshop past couple years. Flywheel has some rust on it. Have gone over it lightly with a scotchbrite a couple turns already but didn’t wanna risk making the surface uneven so removed basically only the orange surface dust. Went a bit harder on the area where the pressure plate mounts and seems most of it comes off with a couple more passes. How bad of an idea would it be slapping this on and using as is? Seems there‘s a very slight orange-peely like texture on the flywheel side when shining a light and looking at an angle. Pressure plate seems kinda fine but at the same time seems like there is a bit of similar pitting / orange peely like texture beneath the machining lines? No rust / discoloring tho. Clutch is a 6 puck rated for 900nm going onto a 350nm car so was hoping it could work as is but guessing the answer will be it need resurfacing and just need someone to confirm the bad news . Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 20, 2023 Share Posted July 20, 2023 Personally Id replace it, and if you do get a clutch moe suited to your torque, 900 is huge overkill and you'll probably hate using it Quote Link to comment Share on other sites More sharing options...
SmuleH Posted July 21, 2023 Author Share Posted July 21, 2023 13 hours ago, Swampy442 said: Personally Id replace it, and if you do get a clutch moe suited to your torque, 900 is huge overkill and you'll probably hate using it Replace it? Not resurface it? And yeah I know it’s overkill. Kind of a «cheapo» quick project so don’t wanna be spending more on it. Have driven some ACT / spec 6-pucks before and tho not the most optimal choice for this, I’m fine with it. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 21, 2023 Share Posted July 21, 2023 In my opinion yes, its pretty heavily pitted, would only be a couple of hundred quid to replace, probably half that or more to get it machined. Quote Link to comment Share on other sites More sharing options...
