Creaking when start and stop
Tommyg_5
I get quite a loud creaking when starting and stopping, nothing when driving and not over bumps.
Had the engine out recently so torqued up all the front suffrage bolts, none of which were loose.
My mechanic took a look and couldn't see anything obvious.
Sounds most likely from the back. Anyone got a checklist I can go through?
I’d check that your rear subframe bolts are torqued up as well.
Anti-roll bar bushes can give that kind of creak. They’re easy to remove. Try re-greasing them first to see if the noise stops as that may confirm the fault before you spend money replacing them.
