Nash Posted July 8, 2023 Share Posted July 8, 2023 As in the last week my car made a noise around the pulley area so I want to see if anyone has had similar and what it might be !!! Link to comment Share on other sites More sharing options...
Nash Posted July 8, 2023 Author Share Posted July 8, 2023 PXL_20230708_160755933.mp4 Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 8, 2023 Share Posted July 8, 2023 Auxillery Tensioner most likely. Had a few squeak like that when they are knackered whilst idling. If you look closely, you can see it jumping around, shouldnt do that Link to comment Share on other sites More sharing options...
Nash Posted July 8, 2023 Author Share Posted July 8, 2023 20 minutes ago, Mike2JZ said: Auxillery Tensioner most likely. Had a few squeak like that when they are knackered whilst idling. If you look closely, you can see it jumping around, shouldnt do that Thanks for that, is that the one top right in the video ? Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 8, 2023 Share Posted July 8, 2023 This guy 1 Link to comment Share on other sites More sharing options...
Nash Posted July 9, 2023 Author Share Posted July 9, 2023 Cheers Mike, I read I may I can change the bearing of the wheel to see if that fixes it rather than all of it ? Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 9, 2023 Share Posted July 9, 2023 That clicking is typically from the auxillery tensioner itself rather than the bearing. But if you take aux belt off and spin the wheel by hand you can determine if bearing is bad. Normally if the bearing is bad then you will feel a lot of side to side movement on it. Link to comment Share on other sites More sharing options...
Nash Posted July 9, 2023 Author Share Posted July 9, 2023 Cheers, I'll give that a go first this week Link to comment Share on other sites More sharing options...
Nash Posted July 11, 2023 Author Share Posted July 11, 2023 How long should it take a mechanic to fit a new tensioner if I need it all ? Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 11, 2023 Share Posted July 11, 2023 15-20min Link to comment Share on other sites More sharing options...
Nash Posted July 11, 2023 Author Share Posted July 11, 2023 Cheers Mike Link to comment Share on other sites More sharing options...
Nash Posted July 13, 2023 Author Share Posted July 13, 2023 On 7/11/2023 at 3:55 PM, Mike2JZ said: 15-20min Could I fit it ? Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 13, 2023 Share Posted July 13, 2023 Don’t let your dreams be dreams 3 Link to comment Share on other sites More sharing options...
Nash Posted August 11, 2023 Author Share Posted August 11, 2023 My garage fitted new belt and Tensioner last week which sorted issue, unfortunately my alternator I fitted 22 months ago caught fire last night on starting !!! 1 Link to comment Share on other sites More sharing options...
AC93 Posted August 12, 2023 Share Posted August 12, 2023 16 hours ago, Nash said: My garage fitted new belt and Tensioner last week which sorted issue, unfortunately my alternator I fitted 22 months ago caught fire last night on starting !!! Bloody heck, hopefully not much damage?! Link to comment Share on other sites More sharing options...
Nash Posted August 12, 2023 Author Share Posted August 12, 2023 9 hours ago, AC93 said: Bloody heck, hopefully not much damage?! On starting I saw smoke across the headlights, turned off engine and on opening bonnet the alternator then started burning with flames so ran in house and got bowl of water to put out, new one on order from Halfords for £168, Lucas 100 amp Link to comment Share on other sites More sharing options...
