SIMON LC Posted April 10, 2023 Share Posted April 10, 2023 Ok so I currently have a 96 facelift non turbo. I plan to whifbitz turbo it. My plans are to buy a Lexus 2JZ engine and rebuild it and fit the turbo kit so it’s ready to go. Am I right to assume short block, head, pistons,crank are all supra same? I assume sump will be different and obviously engine mounts. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted April 11, 2023 Share Posted April 11, 2023 There is a good video by Rad Dan on the difference in 2JZ engines. I think the big main differece is depending on if its a GTE or GE head the bolt patterns are different for both manifolds I believe. 1 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 11, 2023 Share Posted April 11, 2023 You'll need the Supra wiring loom, and engine mounts, and I think water pump unless you're running electric Quote Link to comment Share on other sites More sharing options...
AC93 Posted April 12, 2023 Share Posted April 12, 2023 Lexus will be a 2JZ-GE VVTi, has thinner/weaker rods but you can put the non vvti ones in Quote Link to comment Share on other sites More sharing options...
