Help supra won’t turn over or crank
Paul372
Having problem starting supra tt auto it won’t turn over or crank seems like it’s dead but it has  power, battery is good all lights etc working, also tired jump leads no joy. It’s currently under cover so thought I would air it and start it up, I did this about month ago with no problem started first time now seems dead not even any clicking, any ideas what could be the cause thanks
you can check at the starter relay - one contact is voltage via 7.5 fuse - ignition switch , neutral switch to the contact , the next contact on the relay is voltage from large supply fuse to relay , this is the voltage supplied to the starter , you should feel the relay click , if clicking - then its likely the starter motor itself and it requires battering with a hammer in the first instance - then removing stripping cleaning fixing or a replacement - simple voltmeter tests needed
  • 2 weeks later...
Given the starter motor a few hits, brake lights are working so can’t be brake switch, rocked the supra back and forth, tried starting it up in neutral, moved the gear lever back and forth still nothing. Is there a safety switch on the auto gearbox that could stop it from cranking
You check at your starter relay - use a voltmeter and measure - 1 pin has the voltage from fuse7.5 amp via ignition switch via neutral switch and via immobiliser if fitted - 12 volts when you turn the key = all good . the next pin on the starter relay mount has supply to the starter motor to signal it to crank - measure here for 12 volts ,all good then the problem is at the starter itself - the heavy duty lead to power it or its lost its earth -via the block itself - or the 12v crank supply - all good ? then your starter needs replacing - take it off and try it on the bench with a battery where you can see it engage and turn - hold on to it !!!!
If you dont get 12v from switching the ignition switch - here is your problem - no neutral switch or fuse or ignition switch or immobiliser - so you check at the neutral switch on the gear lever side of the gearbox with a voltmeter or check the fuse is ok or the ignition switch is actually switching (they do fail)
  • 1 month later...
