sidewaysdan Posted February 25, 2023 Share Posted February 25, 2023 (edited) Hi guys and girls. so after 8 years of mostly sitting in a nice garage it’s time to let it go. Just a quick insight to my car . Been a member since 2008 and this is my 2nd supra and had it since 2015 Thanks Dan £30k ENGINE. 2jz-ge compression lowered to 9.5-1 TT head gasket 630cc seimens dekka injectors t61 trubo .70/.68 60mm Demon tweeks external wastegate . Strengthen Xs-power manifold. Auto barn front mount intercooler with custom 2.5”hard pipe kit. New walbro 225 fuel pump with uk spec fuel pump ecu 4 runner distributor twin elec fans wired to switch greddy emu mapped to 1.2bar mapped by Lyndon (nodalmighty) Engine was refreshed by dr-j @ rocket dog racing . Acl race bearing. All new oe gaskets New rings engine probably done less that 3.5k miles. TRANSMITION the excellent david p hybrid auto pressure switch at max fully shimmed valve bodies a01 diferential SRD Twin oil coolers OTHER JR10 alloy wheels now refurbished in gloss black less that 100 mls front 8.5x18 Toyo proxes t1 235/45/18 rear 9.5x18 achillies 275/40/18 all done less than 100mls j spec m-tech front drilled and grooved disc new .less than 100mls on them UK glass headlights TRD spoiler with carbon blade and end caps. stock spoiler Suspension Tein super street coilovers . All new drop links Inside Recaro speed replicas from whifbitzo As new Defi oil temp,oil pressure,water gauges with defi controller in carbon glove box . Aem tru-boost. APR aft gauge Had the front main seal and cam cover gaskets done. Front and rear bushes and drop links . Also just fitted a new alternator Car was re sprayed by Dr j when he had it. I’ve had a stage 2 polish and it’s come up lovely. Parts to go with 3” exhaust Xs-power ffic Stock spoiler AET BW s364sxe ecu master black with plug + play harness for a NA-T tt front intake welded to na lower runners . For na. Oil changed pretty much every 250mls or so . As I get bored and want something to do Edited November 10, 2023 by sidewaysdan (see edit history) Link to comment Share on other sites More sharing options...
sidewaysdan Posted February 25, 2023 Author Share Posted February 25, 2023 1 Link to comment Share on other sites More sharing options...
