Guest sly Posted October 15, 2005 Share Posted October 15, 2005 hi to anyone who can help. i have fitted a toad alarm to my 1994 tt, all works fine, but the unlock does not happen once the drivers door has been shut? works fine ir the door is open? have checked the output from the alarm and it pulses each time the fob is pressed? any one got any ideas, do i just disconect the door switch or is there something else i should try first. thanks to all sly:shrug: Link to comment Share on other sites More sharing options...
merckx Posted October 15, 2005 Share Posted October 15, 2005 I fitted my Toad alarm a few months ago, I connected the wires from the alarm to the central locking terminals in the fuse box in the drivers footwell. Didn't need to do anything else. I've got a facelift car, I would be surprised if the wires are different. Toad Ai606 ..........................Car Fuse Box (Both wires at top of fuse box) Unlock ( Blue/Red )------------( Red/green ) Lock ( Grey/Red )--------------( Red/White ) Ground ( Red/Black ) Ground ( Red/Yellow ) Link to comment Share on other sites More sharing options...
edd_t Posted October 16, 2005 Share Posted October 16, 2005 the exact same happens to me. have been told that the door lock mech on drivers side isnt strong enough! sort of proved it by leaving the engine running, then closing the door and arming the alarm. whilst engine is still on, dis-arming the alarm and the door lock works fine! Link to comment Share on other sites More sharing options...
Guest sly Posted October 16, 2005 Share Posted October 16, 2005 hi thank you both, the face lift model has the same loom i think as i have made the same conections as you described,how did you overcome the unlock prob? in the end? and like i said if the door is very slightly open then all works fine? Link to comment Share on other sites More sharing options...
