evinX Posted December 1, 2022 Share Posted December 1, 2022 My na auto to na manual has developed a rough/ hard start for a few seconds when its really cold. After a drive idle is fine and restarting the car is fine. Had a new fuel pump a few years ago walbro gss442 iirc Runs a na manual ecu I use e5 fuel Finding it difficult to find the culprit. Id has happened before when i was na auto but on the odd occasion. Seems to be frequent now Cheers Quote Link to comment Share on other sites More sharing options...
Guigsy Posted December 2, 2022 Share Posted December 2, 2022 *sharp inhale through teath* Time for a GTE 1 Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 2, 2022 Share Posted December 2, 2022 On 12/1/2022 at 2:28 PM, evinX said: My na auto to na manual has developed a rough/ hard start for a few seconds when its really cold. After a drive idle is fine and restarting the car is fine. Had a new fuel pump a few years ago walbro gss442 iirc Runs a na mI guessing you have tired the basics plugs, leads and dizzy? if so it could be the earth cable that goes from battery to inner wing then block... i know sounds stupid but i had similar issue on mine and found was doggy earth connection. Worth a tryanual ecu I use e5 fuel Finding it difficult to find the culprit. Id has happened before when i was na auto but on the odd occasion. Seems to be frequent now Cheers I guessing you have tired the basics plugs, leads and dizzy? if so it could be the earth cable that goes from battery to inner wing then block... i know sounds stupid but i had similar issue on mine and found was doggy earth connection. Worth a try 2 Quote Link to comment Share on other sites More sharing options...
evinX Posted December 2, 2022 Author Share Posted December 2, 2022 Just now, Suprakeith said: I guessing you have tired the basics plugs, leads and dizzy? if so it could be the earth cable that goes from battery to inner wing then block... i know sounds stupid but i had similar issue on mine and found was doggy earth connection. Worth a try Will check them out mate cheers Quote Link to comment Share on other sites More sharing options...
