NA rough starting
evinX
My na auto to na manual has developed a rough/ hard start for a few seconds when its really cold. After a drive idle is fine and restarting the car is fine.
Had a new fuel pump a few years ago walbro gss442 iirc
Runs a na manual ecu
I use e5 fuel
Finding it difficult to find the culprit. Id has happened before when i was na auto but on the odd occasion. Seems to be frequent now
Cheers
Runs a na mI guessing you have tired the basics plugs, leads and dizzy? if so it could be the earth cable that goes from battery to inner wing then block... i know sounds stupid but i had similar issue on mine and found was doggy earth connection. Worth a tryanual ecu
I use e5 fuel
Cheers
  • Like 2
Will check them out mate cheers
