rpslaughter1982 Posted November 12, 2022 Share Posted November 12, 2022 Sorry couldn't find by searching, engine bay brackets brings back a lot. Both of these brackets are loose on mine at the moment. What are they called and what's the purpose of them? Many thanks Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 12, 2022 Share Posted November 12, 2022 They hold the front of your subframe to the car, pretty important. Go underneath the chassis rail from the wheel arch and you will see the nuts that are underneath that need to be tightened 1 Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted November 12, 2022 Author Share Posted November 12, 2022 6 minutes ago, Mike2JZ said: They hold the front of your subframe to the car, pretty important. Go underneath the chassis rail from the wheel arch and you will see the nuts that are underneath that need to be tightened Thanks Mike, just moved to spot 1 of the to do list Quote Link to comment Share on other sites More sharing options...
