esskiboy Posted November 4, 2022 Share Posted November 4, 2022 Afternoon, My indicator is not working atm (both inside and outside) however the hazard lights are working. Previous owner did change the speedo dials, not sure if that could be the cause of the issue. Otherwise I am thinking it could be the stalk? Stumped on this tbh and cant drive the car atm. Any help would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
rider Posted November 5, 2022 Share Posted November 5, 2022 Check your kick panel fuse box, 7.5A fuse for the turn signals which I believe is the 3rd one from the left second row down. The hazard lights may be on a separate fuse? Then you are down to the actual switch gear. If you suspect its the actual switch at fault I and I'm sure a few others have these in their spare parts store so it shouldn't be a financial ball breaker. Quote Link to comment Share on other sites More sharing options...
