Mike2JZ Posted October 29, 2022 Share Posted October 29, 2022 Moving to a weld in cage so have my cage and associated parts up for sale. Cusco 5 Point Cage Safety 21, specced with additional harness bar This is a bolt in half cage from cusco. I spec'd it with the additional harness bar for so I could run aftermarket harnesses safely. If you wish to use normal belts and have rear passenger then the harness & cross bar can be left unbolted so rear seats can still have a passenger sit in them. Comes with all bolts and mounting hardware, install is fairly easy and non intrusive for the driver. I have poorly cut up my quarter panel plastics to fit with the cage, so will include these in sale as they will fit straight in with cage without having to cut your own plastics up. Rear upper seat section in good condition, other than foam pushed in where harness bar was mounted. Again, might be worth purchasing with cage as its already worked together so no need to sacrifice another rear seat. Potentially the foam can be pursuaded back into normal location. Rear lower leather seats in good condition, no rips etc. Road legal buckle style genuine takata harnesses. Will use eye bolts to mount lower belt sections and upper section mounts straight to harness bar on cage. I used eye bolts that screwed into factory seat belt mounts and worked great, so would recomend the same to fit these. Individual Prices Cage with plastics: £320 Upper Rear Seat: £50 Lower Rear Seat: £100 Takata Harnesses: £100 If you buy the whole lot as a package then £500. Probably best to collect from SRD as awkward to ship. But could probably pallet to ship it, but will need to quote. Link to comment Share on other sites More sharing options...
Mike2JZ Posted October 29, 2022 Author Share Posted October 29, 2022 Sold Link to comment Share on other sites More sharing options...
