Dnk Posted September 12, 2022 Share Posted September 12, 2022 Who uses them ? I have no problems with my E46 330 but was thinking its been nearly 3 years since the last oil change but mostly due to covid It's only done around 5k. Would an engine flush followed by fresh oil and filter be a good idea or just do a normal oil change ? Quote Link to comment Share on other sites More sharing options...
mplavery Posted September 12, 2022 Share Posted September 12, 2022 instead of using a flush just use a cheaper oil and run that for a bit the change with some decent oil Id rather do that than engine flush Quote Link to comment Share on other sites More sharing options...
Noz Posted September 12, 2022 Share Posted September 12, 2022 4 minutes ago, mplavery said: instead of using a flush just use a cheaper oil and run that for a bit the change with some decent oil Id rather do that than engine flush Exactly same process I do. Or water. Helps give it that fresh scented clean Quote Link to comment Share on other sites More sharing options...
rider Posted September 15, 2022 Share Posted September 15, 2022 I've used SeaFoam SF16 additive in engines. its a low dosage of 25g per litre of oil but it has given some interesting results. One engine that has oil changes every 500 miles due to low annual mileage had some top end varnish that I ran for 200 miles with some SF added and the then drained oil was red; resembled used ATF. Most of the varnish has gone, I'm planning on repeating the treatment at some stage. On another engine that had a sticking valve lifter the oil always drained like new as the car was low annual mileage and has at most 1,000 mile between changes. After 250 miles with the SF added to the engine oil it drained black. I like SF because it appears to dissolves deposits rather than disperse them. 1 Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 15, 2022 Author Share Posted September 15, 2022 14 minutes ago, rider said: I've used SeaFoam SF16 additive in engines. its a low dosage of 25g per litre of oil but it has given some interesting results. One engine that has oil changes every 500 miles due to low annual mileage had some top end varnish that I ran for 200 miles with some SF added and the then drained oil was red; resembled used ATF. Most of the varnish has gone, I'm planning on repeating the treatment at some stage. On another engine that had a sticking valve lifter the oil always drained like new as the car was low annual mileage and has at most 1,000 mile between changes. After 250 miles with the SF added to the engine oil it drained black. I like SF because it appears to dissolves deposits rather than disperse them. Dispersing them is just going to cause trouble so dissolving any deposits is much better. Thanks for the info. I'm going to get a sample of the oil and see what it looks like. The engine runs perfectly so I don't want to create a problem My engine oil is on its way along with a new genuine filter Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 16, 2022 Share Posted September 16, 2022 Would absolutely not flush an oil engine, all you'll do is disturb years of crap hiding in nooks and crannies, and send it round your oil system. I always put some cheap oil in, run it for a few miles then change it for whatever you normally use 1 Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 16, 2022 Author Share Posted September 16, 2022 (edited) 14 minutes ago, Swampy442 said: Would absolutely not flush an oil engine, all you'll do is disturb years of crap hiding in nooks and crannies, and send it round your oil system. I always put some cheap oil in, run it for a few miles then change it for whatever you normally use I've been speaking to my friend who owns the local garage i use and he's stopped doing flushes some time ago due to problems afterwards. Booked in on Thursday to do the oil & filter change Edited September 16, 2022 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
