Suprakeith Posted September 11, 2022 Share Posted September 11, 2022 Right am after some help or advice please, got annoying issue with rec counter not working. Since getting my car back from mapping the rev counter hasn't worked, took her back to MGT yesterday for Garth to try few ideas but still no joy and we removed clocks fitted in different supra and all working fine. I've got a GE engine with is now NA-T and am running whifbitz R35 coils conversion with Link G4+ ECU and no matter what we try can't get rev counter to work, have tried bypassing resistor behind Tacho with wire and also taking feed from coil 1 and still joy at all, does anyone have any tips or know what we doing wrong please? as would really like to get rev counter in next few weeks ready for taking car down strip at Santa pod. Any help or know how is really appreciated Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 11, 2022 Share Posted September 11, 2022 Cause your loom is GE you will be missing a tachometer circuit that the Link is expecting to have as they were designed to work with GTE loom. Basically you will need to run a new wire from A16 on ECU (aux 1) to Pin29 on orange passenger footwell connector. 5 Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted September 12, 2022 Author Share Posted September 12, 2022 4 hours ago, Mike2JZ said: Cause your loom is GE you will be missing a tachometer circuit that the Link is expecting to have as they were designed to work with GTE loom. Basically you will need to run a new wire from A16 on ECU (aux 1) to Pin29 on orange passenger footwell connector. Thank you so much will take car back to Garth next week and give that a go Quote Link to comment Share on other sites More sharing options...
