Homer Posted August 28, 2022 Share Posted August 28, 2022 We can’t seem to get the spigot to release. It shifted about 0.5mm but now won’t move anymore, instead tightening the removal tool just bends the bolts that go into the spigot. Any tips? Is heat okay to use since the whole point of this is the replace the front main seal? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 28, 2022 Share Posted August 28, 2022 Remove this tab by unscrewing the m6 bolt that holds it in. With that tab in there it won’t let the spigot move beyond that point 5 Quote Link to comment Share on other sites More sharing options...
Homer Posted August 28, 2022 Author Share Posted August 28, 2022 @Mike2JZ Bloody hell, missed that on the guides. Thanks Mike 2 Quote Link to comment Share on other sites More sharing options...
Homer Posted August 29, 2022 Author Share Posted August 29, 2022 Turns out it wasn't this tab stopping it, we didn't get far enough for it to hit it. The bolts we were using on the puller weren't strong enough. Swapped for some HSS ones and it slowly came off Quote Link to comment Share on other sites More sharing options...
