tayr Posted August 9, 2022 Share Posted August 9, 2022 I've now swapped out my small j spec battery with a bigger Bosch one. Which matches the halfords ones. Does anyone know if the pre-facelift battery insulator (28870-46030) will fit? I ordered 46070 before and it's too small. Also i need a new clamp for the top. Before i buy one from toyota can anyone confirm 74404-14321 is correct for a bigger battery? Length232 mm Width173 mm Height inc. terms225 mm Thanks in advance Link to comment Share on other sites More sharing options...
Homer Posted August 27, 2022 Share Posted August 27, 2022 I’m not sure if you got this sorted out, but for reference you can use the following for larger Euro batteries: Battery terminal (positive) UK spec: 90982-05037 Positive terminal cover (UK spec): 82821-50050 Battery clamp (UK spec): 74404-14320 Note on the battery clamp, the part number you listed is the jspec only one so it’s possibly for the smaller battery. Btw, I accidentally ordered two new battery clamps for my build so let me know if still need one. Link to comment Share on other sites More sharing options...
