Temperature gauge
Biggyinny84
The thermostat doesn't control the operating temperature, just the temperature at which the thermostat allows water to flow. If you remove a thermostat completely, the engine will just take longer to warm up.
If you are questioning the reading then you should look to the sender unit at the base of the radiator or the gauge reading to confirm the current reading is accurate.
