shifted Posted July 23, 2022 Share Posted July 23, 2022 G'day fellow Supra owners, hope you're well! Looking for a parts list for the major service for the VVT-i 2JZ-GTE (Series 2) if someone happens to have the part numbers to go with the list? I understand the below is the list itself (please correct if you notice something is off?) JZA80 Supra 100,000km Service Parts - Twin Turbo (2JZGTE) Part Quantity Cambelt 1 Tensioner Bearing 1 Hydraulic Tensioner 1 Water Pump 1 Camshaft Oil Seal 2 Front Crankshaft Oil Seal 1 Rear Main Oil Seal 1 Harmonic Balancer (Crank Pulley) 1 Fuel Filter (Up to Feb 94) 1 Fuel Filter (Mar 94 On) 1 Air Filter 1 Oil Filter 1 Engine Sump Plug Washer 1 Ignition Coil 6 Coil Housing Connector Harness 6 Thermostat 1 Thermostat Gasket 1 Serpentine Drive Belt 1 Shift Control Yoke (6 Speed) 1 Platinum Spark Plug 6 PCV Valve 1 PCV Valve Grommet 1 Am hoping someone has saved a list or has an excel file with all the good stuff. Also, anyone taken off the side skirts and got a photo of all the original clips and where they go and their part numbers? I've tried searching but I can't seem to make it work well for me, and the AUS Supraforums has a lot of broken links... If I've missed it somewhere, apologies. Thanks! Kind regards, Paul Quote Link to comment Share on other sites More sharing options...
Wishieftrottle Posted July 25, 2022 Share Posted July 25, 2022 Sidenote: If you are changing vvti camshaft seal, also buy 90210-26002. It is gasket for vvti gear Quote Link to comment Share on other sites More sharing options...
Wishieftrottle Posted July 25, 2022 Share Posted July 25, 2022 About part numbers, very useful is amayama.com, where you can put your vin code and see all part numbers in diagrams - example here: Quote Link to comment Share on other sites More sharing options...
Wishieftrottle Posted July 25, 2022 Share Posted July 25, 2022 Detailed tutorial about sideskirts assembly with part numbers is in this video: Quote Link to comment Share on other sites More sharing options...
TuneR Posted July 25, 2022 Share Posted July 25, 2022 Heres my Excel list, has some of your stuff in it. Timing belt 13568-49036 TB tensioner 13540-46030 TB idler bearing 13505-46041 Accessory belt tensioner 16620-0W026 Oil pump 15100-46052 Water pump, OEM 16100-49847 Crank pulley, OEM 13407-46020 Crank pulley tool 09213-70011 Crank pulley holding tool 09330-00021 Crank pulley bolt 90119-18002 Crank timing pulley 13521-46040 Breather hose: turbo side 12262-46021 Breather hose: intake side 12261-46031 Breather hose: inner 1 12263-46010 Breather hose: inner 2 12264-46010 Plastic key blank 90999-00185 Automatic transmission filter 35330-50010 BOV pipe 1 17349-46010 BOV pipe 2 17344-46040 Boot door stopped upper 67293-14051 Boot door stopped lower 67281-14050 Engine mount 12360-46111 Coil packs VVTI 90919-02216 Coil pack connector 90980-11246 Upper rad hose bracket 90949-01B30 Centre prop support 37230-24090 Prop coupling 37511-30020 Diff drive shaft oil seals 90311-47008 Diff prop shaft oil seal 90311-44005 Rear diff mount1 41651-24020 Rear diff mount2 41651-14020 Brake line-centre Small brakes 47326-14040 Brake line-rear right 47328-14030 Brake line-rear left 47329-14030 Brake line-rear 1way valve 90413-10286 Fuel line-main 77251-14410 Fuel line-return 77255-14420 Fuel line-charcoal canister 77262-14070 Breakdown of whats in Seal and gasket set: GASKET, CYLINDER HEAD 11115-46052 GASKET, CYLINDER HEAD COVER 11213-46030 + 11214-46011 GASKET, TIMING BELT COVER, NO.2 11329-46040 GASKET(FOR OIL FILLER CAP) 12195-20020 Water outlet gasket 16343-46030 GASKET, EXHAUST MANIFOLD TO HEAD 17173-46040 GASKET, AIR SURGE TANK TO INTAKE MANIFOLD 17176-46030 GASKET, INTAKE MANIFOLD TO HEAD, NO.1 17177-46031 GASKET, EXHAUST MANIFOLD, NO.2 17198-46010 GASKET, EXHAUST GAS CONTROL VALVE 17281-46010 GASKET, THROTTLE BODY 22271-46080 INSULATOR, INJECTOR VIBRATION 23291-75010*12 + 23291-76010*6 WASHER, SEAL(FOR CYLINDER HEAD COVER) 90210-07001 WASHER, SEAL(FOR HEAD TO CAMSHAFT BEARING CAP) 90210-08033 INJECTOR ASSY, FUEL 90301-14006*6 + 90301-17007*6 SEAL, OIL(FOR CAMSHAFT) 90311-40020 GASKET(FOR FUEL PRESSURE REGULATOR) 90430-16012 GASKET(FOR UNION BOLT NO.1) 90430-12026 GASKET(FOR UNION BOLT NO.2) 90430-12026 GASKET(FOR PULSATION DAMPER HOSE) 90430-12026 BOLT, UNION(FOR NOZZLE LEKAGE PIPE NO.3) 90430-12026 GASKET(FOR FUEL PIPE) 90430-14008 Oil control valve pipe washers 90430-16012 SEAL OR RING, O(FOR VALVE STEM OIL) 90913-02088*12 + 90913-02090*12 GASKET, EXHAUST PIPE 90917-06043 RING, O(FOR OIL PUMP) 96721-24022 RING, O(FOR WATER BY-PASS PIPE) 96761-24023 GASKET, TIMING BELT COVER, NO.1 11328-46041 GASKET, OIL STRAINER 15147-46010 GASKET, TURBO OIL OUTLET, NO.1 15472-46010 GASKET, WATER INLET HOUSING, NO.2 16325-46010 GASKET, WATER INLET HOUSING, NO.1 16325-62010 SEAL(FOR CRANKSHAFT) 90311-46001 SEAL, ENGINE REAR OIL 90311-90006 GASKET(FOR OIL PAN DRAIN PLUG) 90430-12031 Quote Link to comment Share on other sites More sharing options...
