Big Supes Posted July 14, 2022 Share Posted July 14, 2022 Can anyone recommend high quality vacuum hose for my wastegate/boost set up? I need some 6mm and some T-pieces. I was thinking about heading my local Hypahose, but thought I'd check to see what others are using. Quote Link to comment Share on other sites More sharing options...
m12aak Posted July 14, 2022 Share Posted July 14, 2022 I've used plain silicone in the NA with good results, when I get around to refreshing the TT's stock lines again I'm going to use Gates reinforced hose as this thread recommended: 1 Quote Link to comment Share on other sites More sharing options...
Big Supes Posted July 14, 2022 Author Share Posted July 14, 2022 52 minutes ago, m12aak said: I've used plain silicone in the NA with good results, when I get around to refreshing the TT's stock lines again I'm going to use Gates reinforced hose as this thread recommended: Reinforced fuel line is a good shout. I'll see if I can grab some tomorrow for the weekend. 1 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 15, 2022 Share Posted July 15, 2022 Local factors sells Gates hose off the reel which I use, its good quality stuff. 2 Quote Link to comment Share on other sites More sharing options...
Big Supes Posted July 15, 2022 Author Share Posted July 15, 2022 11 hours ago, Swampy442 said: Local factors sells Gates hose off the reel which I use, its good quality stuff. Awesome, thanks mate. I'll get some tomorrow. Quote Link to comment Share on other sites More sharing options...
