redsupra94 Posted June 25, 2022 Share Posted June 25, 2022 Gents, Does anybody have any advice on how to get to the top bolts of the engine mounts? I have a 1994 Auto TT RHD (UK) and I am in the process of replacing my engine mounts and trans mounts as I am getting some vibration. Looking at the mounts the bottom bolts are really easy to get to but the top ones look impossible. Any advice? Any other advice on engine/trans mounts also appreciated. Pics because why not. Thanks! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 25, 2022 Share Posted June 25, 2022 First off, are you 100% sure its engine mounts? Secondly its a bitch of a job, the intake side is fairly easy from the bottom, the turbo side requires creative tool making. I can pull an engine in 2 hours so personally thats what Id do lol 1 Quote Link to comment Share on other sites More sharing options...
redsupra94 Posted June 26, 2022 Author Share Posted June 26, 2022 Thanks for the reply and advice swampy. I'm about ready to say screw it and pull the engine. I've never pulled a TT engine before. Any advice outside of using the TSRM? Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 27, 2022 Share Posted June 27, 2022 (edited) You can remove the brackets if you have many different 14mmm ring spanners (podger with pointy end) ratchets with like 72 teeth etc. They are super tight but once 'cracked' are almost finger tight. So support the engine and the whole bracket with mount can be removed and separated off the car? From memory the turbo side is easier, the intake side i think needs the oil filter housing loosened (or perhaps just the filter removed, can't remember)? The top nuts are really tight and very hard to access with in situ. Edited June 27, 2022 by Scooter (see edit history) Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 27, 2022 Share Posted June 27, 2022 15 hours ago, redsupra94 said: Thanks for the reply and advice swampy. I'm about ready to say screw it and pull the engine. I've never pulled a TT engine before. Any advice outside of using the TSRM? If you intend on doing other jobs, and you have the means to remove it then you'll probably save lots of time that way. It's fiddly, frustrating and you'll need many different combinations of tools/sockets for almost each of the 8 engine mount nuts but it is doable if you don't have an engine hoist/lift etc. 1 Quote Link to comment Share on other sites More sharing options...
mattdavies Posted June 27, 2022 Share Posted June 27, 2022 I did mine when i had the intlet manifold off so that made that side easy, I think you would only need the upper half off I did the exhaust side with alternator and maybe the cat off. Personally there is a big difference between removing a few items and lifting the engine and removing the engine. 1 Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 27, 2022 Share Posted June 27, 2022 These days (I did them years ago) I think a decent compact "right angled impact wrench" with universal join bit might work well for either method (mount brackets or top bolt of the mount itself? 1 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 27, 2022 Share Posted June 27, 2022 Or drop the subframe.... 1 Quote Link to comment Share on other sites More sharing options...
