mc92 Posted June 17, 2022 Share Posted June 17, 2022 I took my car to the garage today because it's been pissing out oil from the front main seal and I'm too lazy to change it myself. They said they would be happy to do the seal, but only if I cleaned all the oil off the engine first. I thought getting oil on you was in the job description for a mechanic 1 Quote Link to comment Share on other sites More sharing options...
evinX Posted June 17, 2022 Share Posted June 17, 2022 If they arnt willing to clean oil off to do a oil seal - AVOID. I did mine myself as a few areas are leaky. And im doing it bit by bit. Still some oil on my undertray but its not the crank seal...have to do my valve covers and suspect my oil filter housing and oil pressure switch also. Want something doing Properly. Do it yourself. Welcome to 2022. 2 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 17, 2022 Share Posted June 17, 2022 Just get a can of brake cleaner and douse the shit out of the front of the engine Quote Link to comment Share on other sites More sharing options...
Big Supes Posted June 17, 2022 Share Posted June 17, 2022 What's the world come to when mechanics are frightened of a bit of oil. Quote Link to comment Share on other sites More sharing options...
Annabella Posted June 17, 2022 Share Posted June 17, 2022 Or Paraffin Quote Link to comment Share on other sites More sharing options...
mc92 Posted June 22, 2022 Author Share Posted June 22, 2022 I decided I'd give it a good blast with the pressure washer, it was indeed very oily. I found one of the bolts I'd lost from the cambelt cover too, which was lucky. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 22, 2022 Share Posted June 22, 2022 Thats been leaking for a while! Quote Link to comment Share on other sites More sharing options...
mc92 Posted June 22, 2022 Author Share Posted June 22, 2022 3 minutes ago, Swampy442 said: Thats been leaking for a while! Yeah, a few years, it's gradually gotten worse to the point where I have become annoyed enough to do something about it. IIRC the timing belt was done not long before I bought it so maybe they didn't change the seals at that time it is a mystery. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted June 24, 2022 Share Posted June 24, 2022 Careful, you've exposed some clean subframe there. Next thing you know you'll be ripping the underside apart to make it all look clean. 1 Quote Link to comment Share on other sites More sharing options...
mc92 Posted June 24, 2022 Author Share Posted June 24, 2022 10 hours ago, mwilkinson said: Careful, you've exposed some clean subframe there. Next thing you know you'll be ripping the underside apart to make it all look clean. Very true. I'm actually considering having the whole thing stripped back and refreshed underneath in a couple of years but I've got some painting to do for now. 1 Quote Link to comment Share on other sites More sharing options...
mc92 Posted July 4, 2022 Author Share Posted July 4, 2022 I took it to another garage and they're having fun with it. Apparently the crankshaft pulley bolt hole had been stripped and helicoiled in the past and they managed to break the helicoil when taking the pulley off. I'm glad I didn't decide to do it myself Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 4, 2022 Share Posted July 4, 2022 The crank shaft pulley bolt hole is the crank! Quote Link to comment Share on other sites More sharing options...
mc92 Posted July 4, 2022 Author Share Posted July 4, 2022 (edited) Not the crank pulley, the timing belt tensioner much better. Edited July 6, 2022 by mc92 (see edit history) Quote Link to comment Share on other sites More sharing options...
