evinX Posted June 8, 2022 Share Posted June 8, 2022 So im going to tackle my valve cover gaskets. As many have suffered i think its time to find a fix for the bolts becoming hand tight due to vibrations. The GEs dont have gaskets for the bolts like GTEs do so im wondering what fixes are out there to lock the bolts and not crack the valve covers. So far my ideas are, 1. Split locking washers 2 . GTE bolt gaskets, thinking the rubber will lock the bolts? 3. Thick rubber washers Any help? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 8, 2022 Share Posted June 8, 2022 They only need to be handtight anyway, most make the mistake of overtightening and snapping the bolt or breaking the valve cover. 1 Quote Link to comment Share on other sites More sharing options...
evinX Posted June 8, 2022 Author Share Posted June 8, 2022 10 minutes ago, Mike2JZ said: They only need to be handtight anyway, most make the mistake of overtightening and snapping the bolt or breaking the valve cover. I find mine are way too lose and the rear leaks onto the box Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 8, 2022 Share Posted June 8, 2022 Make sure you use OEM valve cover gaskets, I only see issues with non oem ones leaking. Never had rockers leak on my NA or others I've done at the rear 1 Quote Link to comment Share on other sites More sharing options...
evinX Posted June 8, 2022 Author Share Posted June 8, 2022 39 minutes ago, Mike2JZ said: Make sure you use OEM valve cover gaskets, I only see issues with non oem ones leaking. Never had rockers leak on my NA or others I've done at the rear Ok, good shout mike as i used blueprint ones years ago. And have oem ones to go on Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 8, 2022 Share Posted June 8, 2022 I remember tightening mine a little after first fitting, they seem to settle/bed in. Also there are a few points to use sealant on them (round the cam 'arch' bits?) Quote Link to comment Share on other sites More sharing options...
mc92 Posted June 8, 2022 Share Posted June 8, 2022 Blue loctite? I've never had that problem personally. Make sure you properly clean the gasket surface and that your cover itself isn't cracked or deformed. I torqued mine by feel so they're probably tighter than they should be. Quote Link to comment Share on other sites More sharing options...
m12aak Posted June 8, 2022 Share Posted June 8, 2022 I used blueprint ones that kept leaking. I went through and tried the GTE washers/blue loctite (to no avail, the blueprint gasket must not be right), and have since moved back to OEM which haven't leaked since! 1 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 8, 2022 Share Posted June 8, 2022 Theres a moral to that tale 2 Quote Link to comment Share on other sites More sharing options...
