tayr Posted June 6, 2022 Share Posted June 6, 2022 (edited) Hi all, looking to install an Oil Temp sensor and gauge for my auto, what’s the best routing up into the car for these? Ideally want to avoid main dash area as I can’t be bothered taking it off again. So thinking either centre console, glovebox or maybe by drivers left leg area. Is there a grommet in the floor to go through under the carpet or am I best off taking it up through gear shifter boot? If that’s even possible on an auto for anyone interested I’ve purchased one of these which saves the hassle of welding a bung in the pan. It replaces the drain plug but has a connection for the sensor. https://www.ebay.co.uk/itm/393547071860?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=YZqzRAmNRHG&sssrc=2349624&ssuid=_Sds6tMnT-q&var=662325860058&widget_ver=artemis&media=COPY Edited June 6, 2022 by tayr (see edit history) Link to comment Share on other sites More sharing options...
evinX Posted June 6, 2022 Share Posted June 6, 2022 There are grommets on the passenger side of the tunnel. I have concerns about using the sump hole for the temp sensor..good idea but id be worried about something catching it and ripping the wiring away. Maybe go in at the side of the sump near the dipstick, drill a hole and use a fitting with a crush washer and a crush washer/ bolt on the inside of the pan? Or drill a hole and tap the sump, but the metals thin. Only thing is you would have to drain the 2l from the pan, drop it and reseal it having to wait near 24hrs for leaks coming down to clear up before resealing. Link to comment Share on other sites More sharing options...
tayr Posted June 6, 2022 Author Share Posted June 6, 2022 Thanks again mate! I’ve got 10 litres of Toyota stuff so I could do it the right way. If it’s a little precarious then I’ll get a bung welded in. The car is stock height tho so would have to bottom out quite badly to rip it off. Might he able to find a 90 degree sensor Link to comment Share on other sites More sharing options...
evinX Posted June 6, 2022 Share Posted June 6, 2022 23 minutes ago, tayr said: Thanks again mate! I’ve got 10 litres of Toyota stuff so I could do it the right way. If it’s a little precarious then I’ll get a bung welded in. The car is stock height tho so would have to bottom out quite badly to rip it off. Might he able to find a 90 degree sensor Take a supra down to all these new retail parks opening up. Bumps are brutal Link to comment Share on other sites More sharing options...
tayr Posted June 6, 2022 Author Share Posted June 6, 2022 40 minutes ago, evinX said: Take a supra down to all these new retail parks opening up. Bumps are brutal That’s ok, I don’t drive my supras I just look at them point duly noted though! 1 Link to comment Share on other sites More sharing options...
Burna Posted June 10, 2022 Share Posted June 10, 2022 On 6/6/2022 at 8:26 PM, tayr said: Thanks again mate! I’ve got 10 litres of Toyota stuff so I could do it the right way. If it’s a little precarious then I’ll get a bung welded in. The car is stock height tho so would have to bottom out quite badly to rip it off. Might he able to find a 90 degree sensor It'll be fine, had my oil temp in the sump plug for over 15 years. If you managed to bottom out and rip that out, that will be the least of your worries if you managed to reach that low! lol I have oil pressure probe, which to me is far more important, in the lexus bolt mod, maybe you can use that for oil temp instead? 1 Link to comment Share on other sites More sharing options...
tayr Posted June 20, 2022 Author Share Posted June 20, 2022 after some investigation i have decided to weld a mild steel bung into the side of the pan, creates a nice safe route for up through the passenger tunnel. Just need to find a reasonably prices temp gauge now. Link to comment Share on other sites More sharing options...
