evinX Posted May 29, 2022 Share Posted May 29, 2022 Going to tackling a few weeping seals on my engine soon. And suspect the oil filter housing is leaking as there oil build up around there. Anyone done it before on a non turbo? Any guides out there? Link to comment Share on other sites More sharing options...
m12aak Posted May 29, 2022 Share Posted May 29, 2022 First few mins shows him talking about/installing an NA housing back on, not done it myself but it looks straightforward especially as there is no cooler/sensor thread in the bolt. The TSRM doesn't mention anything special either: It'd be interesting to hear if it was actually leaking from there rather than it just being residual oil from when the filter's changed in a service. Link to comment Share on other sites More sharing options...
Scooter Posted May 29, 2022 Share Posted May 29, 2022 If you only suspect that seal then check out the oil pressure sensor too, as it's in the same area (but further forward behind the aircon compressor) and can go. Link to comment Share on other sites More sharing options...
