auzzam Posted May 25, 2022 Share Posted May 25, 2022 Hi all, I've tried searching, but have not yet found a definitive answer. I am going to be changing the brake fluid soon and wanted to ask what is the best way to go about this? - my car has ABS if that matters. I know to start from the furthest calliper and work your way back and this worked fine on my MX5. I am just unsure whether the same applies for the supra given some people have mentioned the process may be different as it has ABS. I'm assuming I can bleed all of the callipers with the car switched off - or does it need to be on for the ABS pump to work? My car is a J-Spec with UK front callipers. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
rider Posted May 26, 2022 Share Posted May 26, 2022 If you are bleeding a system then you need to start at the furthest point from the reservoir and work your way around the car. If you are changing the fluid then I suck out as much of the oil fluid first from the reservoir and then top up to the brim with new fluid and just open each nipple and draw through the fluid until it runs new oil clear in the see through plastic line hooked onto the nipple. I doubt it matters which order when you doing a complete flush but I just do the furthest away starting point out of habit. Its all done car off. 1 Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 26, 2022 Share Posted May 26, 2022 We used a Mityvac fluid vacuum when we replaced the calipers and brake lines on my car. Worked well and done very quickly if you have someone topping up the reservoir as you bleed each corner 1 Quote Link to comment Share on other sites More sharing options...
auzzam Posted May 30, 2022 Author Share Posted May 30, 2022 perfect thanks guys! might have to look into the vacuum bleeding 1 Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 30, 2022 Share Posted May 30, 2022 17 minutes ago, auzzam said: perfect thanks guys! might have to look into the vacuum bleeding I was impressed how it well it worked, we went round the system once and job done Quote Link to comment Share on other sites More sharing options...
