Rear Fog Light
Big Supes
They usually disable 1 reverse and put in a red bulb. Then use a fused 2 wire steup with a switch on the dash. Pretty basic. Or you can use the oem UK fog switch
Id imagine you cut and heatshrink the 2 oem wires then add your new 2 wires to the bulb socket wires
Edited by evinX (see edit history)
As yours is UK Spec then it would require you to re pin one side to the OEM fog light pin and then change the bulb colour.
I think its 6 pin connector and on the UK they should all be full on the chassis loom side and then one missing on the light side, just use a multimeter to work out which is which and then de pin the reverse wire and re-pin it opposite the fog light wire on the chassis side.
I hope this makes sense
