1993 Toyota Supra SUPRA TURBO 2JZ BIG TURBO WIDE BODY
Saad
Hello my fellow Supra MKIV enthousiasts, i am a salesperson at a dealership looking for your expertise in the supras to give an estimated appraisal on this car, it is our dealer's owner personal car so it is not cheap but i was thinking i would look into forums to get an approximate value for the car from no one else than the most knowledgeable people in the market.
Original USDM 1993 6-speed turbo supra with targa top; it has clean title. No accidents. Car has 124k miles
It currently run 572whp@20psi with 488 wtqs
Pro:
- The engine and turbo have been rebuilt in 2018
- clutches and transmission have been rebuilt 2019
- Driveshaft upgrade in 2018
- All unnecessary wire have been removed
- Shaved bay and wire tucked
- Ready for more power
Cons:
- rear bumper have been shaved and side skirt too
Here’s a list of the upgrade
ENGINE / PERFORMANCE
Turbo Precision 74GTS rebuilt 2018
Manley turbo tuff rod 2018
Cp hd wrist pin forged piston 86.5mm 8.5-1 2018
ARP head studs 2018
ARP rod bolts 2018
ARP main stud 2018
ACL race bearings 2018
Head Port and Polished
Brian Crower Titanium springs
Brian Crower Titanium retainers
HKS 272 camgears
GM LQ9 coil kit
Titan Adjustable Cam Gears
Titan Crank Damper
Titan ported oil pump 2018
Titant spring valve and retainer 2015
Horsepower Freaks exhaust manifold 2015 ceramic coat 2018
Horsepower Freaks 4" Downpipe ceramic coat 2018
Apexi catback exhaust
Tial 44mm Wastegate
Tial 50mm Blow Off Valve
Greddy 3-row intercooler 2015
Godzilla intake manifold
100mm throttle body
Mishimito Radiator 2015
Silicon Radiator hose kit
Weldon 2047 FPR
Aeromotive -10 an Fuel filter
Magnafuel MP-4303 650LPH fuel pump 2015
Stainless fuel lines -10 AN
Precision 1000cc injectors
AEM 5-bar map sensor
Titan motorsports -8 an dual feed fuel rail
Spec Super Twin SS clutch kit with flywheel 2019
ARP flywheel bolt 2019
Wilwood master cylinder 2019
Transmission inspection plate
DERALE dual eletronic fan kit 4000 cfm
Driveshaftshop 3.5’’ chromoly driveshaft 2018
Differential bushing super pro 2019
TRD oil cap
ELECTRONICS / INTERIOR
AEM V1 standalone management system
Carbon (real) Dash kit
HKS DLI
LED cluster gauges
AEM wideband
AEM Boost gauge
AEM Oil pressure gauge
Pioneer double din radio
Oem speaker amp
Alpine Speakers
OEM JDM steering wheel
Oem seat with ridies leather with white stiches cover
New Supra Floor mats
Complete wire tuck (removed abs, trac, a/c, air bag, cruise)
Fusebox relocated
9005/9006 Carlighting district hi/low headlight
SUSPENSION / CHASSIS / BRAKES
Powered by MAX coilovers
Cusco rear strut tower bar
TRD Engine mounts
TRD transmission Mount
TITAN shifter bushing
Stoptech brake disks, pads & lines
Carbon Fiber hood dampers
Carbon fiber trunk dampers
TRD front strut barTitek Carbon cooling plate
ABS delete kit
AC delete kit
Engine bay shave
Gloss Black powder coat
Wire tuck
N/A rear break (still have te tt ones)
EXTERIOR / AERO
TRD widebody rear fenders and rear bumper
Do-Luck side skirts
Oem front bumper
Wingless! (shaved trunk)
Full tint windows
Paint
Engine bay white
WHEELS / TIRES
DPE CS5 custom 3 pieces forged wheels
front: 19x10+30 on toyo 245/30R19
Rear: 19x12+15 ont toyo 315/25R19
Id recommend getting a proper evaluation done. It's fairly low cost and would help you provide a sale price.
Of course, these are mostly done for insurance. But still give you an accurate idea.
You'll get a mixed bag of opinions on here. Evaluations use example sales.
@tayr
