S2 Instrument Cluster Wiring Diagram, Speedo not working
Sebastian
Hello! i didn’t find what i need on search, I’m in need of complete dash wiring diagram for Series2 cluster, can someone give me a link or some pictures how its done? The speedo worked when i bought the car, And all of a sudden it stopped working, I have checked everything without making it work, The Blue/red is hooked up that it the speedsensor, I have also installed new cables direcly from the speedsensor, 12v and ground. But nothing happens.. The car has series 2 speedometers installed in a 1995 Supra, so I dont know if they have connected it in any other way.And now I need your help how to fix this. Fuel gauge,Watertemp,RPM tacho is working.
* Car is JDM 1995 Mkiv 2jz GTE 6spd.
Edited by Sebastian (see edit history)
  • 2 weeks later...
Have you verified you're getting a good signal from the speed sensor ?  Check where the L-R Blue-Red wire goes into the odometer - that assembly is fragile and prone to solder cracks.  I had to touch up all the solder joints on mine some years ago.  Open it up carefully, dab a bit of flux on each joint and hit with a soldering iron.  Also check the ribbon cable - it too is fragile.
