AC Condenser replacement
spinthepilot
23 minutes ago, spinthepilot said:
Sadly they are not compatible with my 2001 Supra 😞 Thanks much anyway.
Are you 100% sure? I don’t remember seeing any different part numbers when checking pre/post facelift, worth a double check if you are unsure.
If you used the eBay compatibility checker it may be the case that seller set it up wrong as in the US they only got them until 1998 so any car later than that is automatically incompatible?
38 minutes ago, Burna said:
I did not no that!! So they suit pre-facelift only?
I know Koyo are now making AC condensers, but don’t know if it’s for facelift too. Lee at SRD will be able to confirm, as I know he’s got some on the way to him 🙂
According the compatibility list on that ebay listing
I wouldn’t trust that mate, as I friend has just been ordered the same one for his facelift supra, same part number. Check the EPC and check the part number to suit your car, I’ll bet they are the same.
