mwilkinson Posted February 5, 2023 Share Posted February 5, 2023 (edited) I asked Lee at SRD the other day about them whilst picking up a new windscreen. He was the one that gave me the heads up that they were back in stock. What springs are you going to use? Edited February 5, 2023 by mwilkinson (see edit history) Link to comment Share on other sites More sharing options...
wile e coyote Posted February 9, 2023 Author Share Posted February 9, 2023 So booked for 27th to start laying down colour woop woop 1 Link to comment Share on other sites More sharing options...
Wishieftrottle Posted February 9, 2023 Share Posted February 9, 2023 I cannot wait to see it! Link to comment Share on other sites More sharing options...
wile e coyote Posted February 9, 2023 Author Share Posted February 9, 2023 On 2/5/2023 at 9:07 AM, mwilkinson said: I asked Lee at SRD the other day about them whilst picking up a new windscreen. He was the one that gave me the heads up that they were back in stock. What springs are you going to use? im going to use stock springs 2 Link to comment Share on other sites More sharing options...
wile e coyote Posted February 23, 2023 Author Share Posted February 23, 2023 Not much to add Some blasting , can see difference between Vapour and sand, Vapour is more hard wearing and oem Finnish ea65d893-039f-45f0-b762-2c8793417197.mp4 Link to comment Share on other sites More sharing options...
wile e coyote Posted February 23, 2023 Author Share Posted February 23, 2023 Steering rack had leak so rack pump stripped and sent off for rebuild Injectors going off for ultrasonic cleaning and flow testing Turbos sent off , Specified Basic rebuild with ported wastegates (no restrictor ring needed) 2 Link to comment Share on other sites More sharing options...
mattdavies Posted February 24, 2023 Share Posted February 24, 2023 Loving the detail you are going to on this. Will be great once its done. You and @Chingy with your Restored OEM cars. 2 Link to comment Share on other sites More sharing options...
Wishieftrottle Posted February 24, 2023 Share Posted February 24, 2023 Are you going to protect the alu parts after blasting? With color, clear coat, or some chemical protection to keep it fresh? Link to comment Share on other sites More sharing options...
rider Posted February 24, 2023 Share Posted February 24, 2023 (edited) 2 hours ago, Wishieftrottle said: Are you going to protect the alu parts after blasting? With color, clear coat, or some chemical protection to keep it fresh? There can be issues with clear coating aluminium parts that is common to any clear coat paint, it degrades with time quickened if its in a harsh environment and can craze, crack, cloud, yellow and chip. You can anodise aluminium to give it a ceramic look or apply a silicone spray sealant that would need a regular interval wipe down and reapplication if the clean look is important to you. Edited February 24, 2023 by rider (see edit history) 1 Link to comment Share on other sites More sharing options...
wile e coyote Posted February 24, 2023 Author Share Posted February 24, 2023 not doing anything, with the vapour blasting it makes it smoother so won't hold dirt as easy like just media blasting 1 Link to comment Share on other sites More sharing options...
wile e coyote Posted February 26, 2023 Author Share Posted February 26, 2023 So I got this apex sports cat as looks oem and will get it through any emissions Designed for the vvti just can't seem to get a stock one 1 Link to comment Share on other sites More sharing options...
rider Posted February 26, 2023 Share Posted February 26, 2023 I have a spare 1st and 2nd pre-facelift cats (actually the originals to my car) and I'm sure other parts hoarders do to so they are about. After a few decades, they may well be a bit rusted on the heat shields but those could be replaced with new aluminium sheet metal. 1 Link to comment Share on other sites More sharing options...
wile e coyote Posted February 26, 2023 Author Share Posted February 26, 2023 When I originally got my car it only had a second cat which I got rid of when I changed my exurst like most of us did lol The first decat apparently is different between pre vvti and vvti I have I stock exhurst to fit but may get a new tip Link to comment Share on other sites More sharing options...
rider Posted February 26, 2023 Share Posted February 26, 2023 I'm pretty sure it was the second cat that is different pre facelift to facelift, the pre has the honeycomb whereas the post has a void. 1 Link to comment Share on other sites More sharing options...
wile e coyote Posted February 27, 2023 Author Share Posted February 27, 2023 So Today she was rolled into the oven to cook for 3 hrs to make sure no moisture is present then left for day to cool Will start to block tomorrow So there will be plenty of updates over the next few weeks 1a2db444-4a00-4a43-80a1-4d3398984ecb.mp4 2 Link to comment Share on other sites More sharing options...
wile e coyote Posted February 27, 2023 Author Share Posted February 27, 2023 Bit more blasting and vapour blasting Again you can see the difference 2 Link to comment Share on other sites More sharing options...
wile e coyote Posted March 1, 2023 Author Share Posted March 1, 2023 So Some progress over last few days Car blocked and rubbed down nicely Panels into primer and look ok already, rest of the car should be primed by saturday Paint tinters all orders to make the colour 1a2db444-4a00-4a43-80a1-4d3398984ecb.mp4 3 Link to comment Share on other sites More sharing options...
Wishieftrottle Posted March 1, 2023 Share Posted March 1, 2023 Very clean job 1 Link to comment Share on other sites More sharing options...
TuneR Posted March 2, 2023 Share Posted March 2, 2023 Happy days, they're putting a lot of work into that so should be a great finish. 1 Link to comment Share on other sites More sharing options...
wile e coyote Posted March 2, 2023 Author Share Posted March 2, 2023 More progress today Body primed and looks nice Last parts in booth to prime tomorrow Bumpers, mirrors, door handles etc so everything will be in high build ready to paint inside of the panels and shuts ect Then panels back on the car to block the car ready for paint Still bit to do 3 Link to comment Share on other sites More sharing options...
wile e coyote Posted March 3, 2023 Author Share Posted March 3, 2023 So remains parts primed in high build and some more vapour blasting done Ordered all new suspension arms and what fuel and brake lines that are available 2 Link to comment Share on other sites More sharing options...
wile e coyote Posted March 5, 2023 Author Share Posted March 5, 2023 Bit more paint done on bonnet and doors Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 6, 2023 Share Posted March 6, 2023 Wow! What an amazing build! James and Kane really are superb at what they do. I used spectral clear on my car and loved the finish it gave. Looking forward to updates on this Link to comment Share on other sites More sharing options...
wile e coyote Posted March 6, 2023 Author Share Posted March 6, 2023 (edited) Couple more bits painted and seam sealer applied Talked about this , we could have done it smooth clean but I'm after it oem so did it oem but tidier Injectors cleaned and tested, turbos all done but no pictures yet Edited March 7, 2023 by wile e coyote (see edit history) 1 Link to comment Share on other sites More sharing options...
rider Posted March 6, 2023 Share Posted March 6, 2023 Are you going to tabulate the cost of all this at the end in time, parts and labour? I did with my underside refurb so it'd only be fair. Always useful for the historical record on the site, though you probably would need a comfy seat and stiff drink by your side writing that part up. 1 Link to comment Share on other sites More sharing options...
