Dragonball to Oem
wile e coyote
  • 2 weeks later...
Hi guys
so not a lot has happened over last week due to James and Kane getting covid so off for the week so dipping date has moved, company was very understanding
so James was on it today and will be this week so imagine a fair bit of progress this week
so he wrestled the alarm out today, not happy as was every where
found some rust around , where the steering column goes through bulk head , which will need work and also round grommet where wiring goes to the rear hatch
  • Like 1
  • Haha 1
So James removed subframes brakes brake lines fuel lines and suspension
some of the arms are useable as I had replaced several years ago
brake fuel lines are as usual and will be replaced
rack will get refurbished with new ends little play in it
rear subframe is the unknown so will get it blasted and see what it’s like , if so I’ll get another
  • Like 2
11 hours ago, wile e coyote said:
Lee at srd has stripped the engine and all good news in very good condition and can use most of it
so just a refresh with new pump gaskets /seals and bearings
What can't you use out of interest.
9 hours ago, tayr said:
Love progress like this, can’t wait to see more updates
Put your little rocket away 😂
"rear subframe is the unknown so will get it blasted and see what it’s like"
Your sub frame will be fine. Its a thick gauge metal.
I had my sub frame oven baked which gets to the inside as well as the outside. All the rust is then easily dissolved inside and outside in an acid dip. There will be rusting inside your frame that blasting simply wont touch.
The bake and galvanizing wasn't expensive when I did it in 2017. Details on the companies used and costing are on my underside refurb project thread if you decide to go that route.
  • Like 1
  • 2 weeks later...
8 hours ago, mwilkinson said:
You're all in on this rebuild, so why cut corners or take chances. You'd just regret it later on.
I assume you'd like to replicate this work on the other rear quarter? Any luck finding a lh new panel?
Yep Other side will be same but can't get new panel so looks like only option is from a donor
All Test fitted and ready to weld now
  • Like 1
