Girlfriend put diesel in my TT!!!!
Baz786
I need help, my loving girlfriend put £7.50 diesel in the TT and then realised what she was doing. She phoned me and I told her to fill up on optimax. £53 of optimax went in and since I've done a 50 mile run. Car has been parked for 2 days now and it wont start??????? what can I do:who:
Seriously.... tho...
You need to:
drain the tank
have the injectors ultasonicly cleaned
flush the fuel lines
New fuel filter
Check the pickup on the pump and clean out
May have screwed your Lambda...
Anyone... have I missed anything?
Very bad idea starting it with diesel in it, no matter how much optimax you put in it!!!
Best not to run the car at all now.
Like Jay said you'll just cause more damage - the Lambda sensor and maybe the catalsts.
Isn't the nozzle on a diesel filler pump larger than an unleaded one, unless the supra isn't I'm not sure how it was possible to put any diesel in.
Is it easy to drain?? Any help would be appreciated
Yeah its pretty easy a few ways of doing it so you can take your choice . Syphon from the tank though the filler or disconect the fuel line at the filter bridge out the fuel pump and and let the pump do all the work for you ..But to be honest I would be more enclined to take the spare wheel out access, the top of the tank and remove the pump carrier and pump it out or syphon from the top to make sure you get every last dreg out . This way you can also clean the filter bag on the bottom of the pump in petrol. I would then remove the fuel filter and blow the fuel line out with air/fresh petrol . I would also While the filter was out Run some fresh petrol up the fuel line from in front of the filter to clean out the rail and return line back to the tank to get any diesel left at that end of the system. Once all that is done and your are 100% sure most of the Diesel is out put it back together with a NEW fuel filter , fill up the tank , prime the system and away you go ;)
one way to drain the tank is remove the fuel relay, bridge the two main feeds so the pump runs constant when ignition is switched on undo the fuel pipe from the fuel return in the boot, attach a longer hose onto the return pipe and pump all the fuel out into a container.
Why? Do they have small Diesel nozels?
Nope just the 'Ultimate' badging on both petrol and diesel pumps can confuse a LOT of people. Lots of people on jap forums have posted up about pumping £40s worth of ultimate diesel rather than petrol into their jap wagons :(
As much as i don't like to admit it, i was so close to doing this, picked up the pump that said ultimate @ bp and only cos it was so greasy in diesel it made me look again, i almost dropped it when i realised i was about to fill up with diesel. Didn't realise until then that bp did ultimate diesel:blink:
I'm not sure that you will need to replace the sparks. The only reason I can see for it is that the tips would be coated in diesel which is an oil so rinsing the tips in white spirit should sort them out especially if they are £60 a set jobbers like mine are. Fuel filter has gotta go no questions. If you have another normal car I'd stick it in that a bit at a time every fill up to use it up but thats just me. I'm not sure myself that you will have done a great deal of damage. If you didn'y get much det then you shouldn't really have caused too many problems.
