Dnk Posted January 14, 2022 Share Posted January 14, 2022 I have windows 8.1. I have 50mbps to my BT Hub, my pc keeps flashing up I'm offline then seconds later restored The connection to my hub is stable and not dropped out according to the BT admin router network I've tried plugging back into the router with ethernet cable and makes no difference apart from its faster Any ideas guys Link to comment Share on other sites More sharing options...
rider Posted January 14, 2022 Share Posted January 14, 2022 Download the freeware version of Advanced Systemcare and scan your PC. The fixes include optimising the internet settings to fix issues and conflicts. I'd recommend uninstalling afterwards as it has some power hungry monitors that will eat into your PC memory unless you are savvy enough to disable the process start ups through your task manager. 1 Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2022 Author Share Posted January 14, 2022 Thanks i'll give that a try Link to comment Share on other sites More sharing options...
Ric Posted January 14, 2022 Share Posted January 14, 2022 although it's saying you're offline, are you actually? Set a ping going to 8.8.8.8 -t which will constantly send untill stopped. If it keeps going you're not actually going offline. Could be a DNS problem if the DNS server you're reaching is poor. Perhaps change this to 8.8.8.8 / 8.8.4.4 1 Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2022 Author Share Posted January 14, 2022 40 minutes ago, Ric said: although it's saying you're offline, are you actually? Set a ping going to 8.8.8.8 -t which will constantly send untill stopped. If it keeps going you're not actually going offline. Could be a DNS problem if the DNS server you're reaching is poor. Perhaps change this to 8.8.8.8 / 8.8.4.4 Good question, i'll have to google doing the ping lol Link to comment Share on other sites More sharing options...
Ric Posted January 14, 2022 Share Posted January 14, 2022 33 minutes ago, Dnk said: Good question, i'll have to google doing the ping lol windows key + r type CMD and enter Type ping 8.8.8.8 -t and enter. If it replies its OK if it says timed out it failed Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2022 Author Share Posted January 14, 2022 2 hours ago, Ric said: windows key + r type CMD and enter Type ping 8.8.8.8 -t and enter. If it replies its OK if it says timed out it failed i just get -- ping request could not find host 8.8.8.8-t Link to comment Share on other sites More sharing options...
pf85 Posted January 14, 2022 Share Posted January 14, 2022 Space required before -t 1 Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 7 hours ago, pf85 said: Space required before -t thanks Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 this is what i get Link to comment Share on other sites More sharing options...
Ric Posted January 15, 2022 Share Posted January 15, 2022 is that during an event where your pc said you were offline? Are you using the supplied BT wifi hub, they are usually very rubbish when it comes to wifi. I would suggest getting a better performing wifi router. But it could also be the wifi card in the laptop. Are other devices having this issue? it will be really difficult to diagnose without being there etc. Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 (edited) 2 hours ago, Ric said: is that during an event where your pc said you were offline? Are you using the supplied BT wifi hub, they are usually very rubbish when it comes to wifi. I would suggest getting a better performing wifi router. But it could also be the wifi card in the laptop. Are other devices having this issue? it will be really difficult to diagnose without being there etc. The events are so fast, the messages of being offline then restored appear in bottom left of my pc I also get connection to XBOX was lost in the top right corner of the screen and the game freezes, this happens a lot now. WhatsApp on my pc also flags up the Red exclamation mark frequently Youtube videos seem not to be affected Yes I'm using a fairly new HUB 2 with a HP pc Edited January 15, 2022 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 (edited) When I just tried to post the above this was the screen I got. Then it posted straight after ok Edited January 15, 2022 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 (edited) 18 hours ago, rider said: Download the freeware version of Advanced Systemcare and scan your PC. The fixes include optimising the internet settings to fix issues and conflicts. I'd recommend uninstalling afterwards as it has some power hungry monitors that will eat into your PC memory unless you are savvy enough to disable the process start ups through your task manager. I ran that and as much as it found lots of stuff my pc its the same but thanks, just deleted it Edited January 15, 2022 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
pf85 Posted January 15, 2022 Share Posted January 15, 2022 (edited) Do you use a VPN or something else which may be trying to control your network connection? Also have you a good uptodate antivirus such as Norton Security? When you tried connecting with a LAN cable, did you disable the WiFi connection? It's very odd that the LAN cabled connection would be dropping in the same way. To better troubleshoot I'd recommend the following: 1. Restart the Router 2. Restart the Computer 3. Open control panel and network > adaptors > right click and disable the wireless WiFi network adaptor 4. Open the settings for your LAN adaptor and check the ipv4 settings - make sure its set to DHCP for everything, proxy is disabled and LAN settings is set to Automatically detect settings 5. Plug in the LAN cable to the router directly Run the ping test again. If its still dropping then you could try resetting all network settings and try ping again. If its still dropping at this point then you should try see if there is a newer driver available to download for your LAN and WiFi devices (I doubt if this will make much difference but its good practice) Also is your Windows correctly activated? Id strongly recommend updating to Windows 10 - this alone might even solve your problem. If you like I could remotely connect into your computer and have a look? I use TeamViewer which is a free piece of software for remotely connecting to other computers - but this is your call as I'd obviously be able to control your computer during this session although you would be watching everything I do on screen. Edited January 15, 2022 by pf85 (see edit history) 1 Link to comment Share on other sites More sharing options...
Annabella Posted January 15, 2022 Share Posted January 15, 2022 As above, disable the WiFi on the PC when you try wired. If the same then it's your router or external broadband connection. As above again if same after wired test then swap the router. If the same it's outside, the problem, log everything you're doing and pass to BT. Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 Used to have AVG but now my pc only has Windows defender and firewall Re started router Re started pc Disabled the wifi The next bit has me lost, i think i opened the LAN adaptor but just got this, i attached a screen shot The Lan cable is plugged into the router Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 23 minutes ago, Annabella said: As above, disable the WiFi on the PC when you try wired. If the same then it's your router or external broadband connection. As above again if same after wired test then swap the router. If the same it's outside, the problem, log everything you're doing and pass to BT. Had BT here and router appears to be fine and the broadband to the house hasn't dropped out according to the engineer who checked on the Smart HUB 2 manager which I've just done. Thought the problem must be from the HUB so plugged in using ethernet cable but didn't disable the wifi and was still the same Link to comment Share on other sites More sharing options...
Annabella Posted January 15, 2022 Share Posted January 15, 2022 14 minutes ago, Dnk said: Used to have AVG but now my pc only has Windows defender and firewall Re started router Re started pc Disabled the wifi The next bit has me lost, i think i opened the LAN adaptor but just got this, i attached a screen shot The Lan cable is plugged into the router The details for the ethernet conn above are correct, can't see if the wifi adapter behind is disabled or not? Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 (edited) 3 minutes ago, Annabella said: The details for the ethernet conn above are correct, can't see if the wifi adapter behind is disabled or not? yes its disabled, i just did it the BT engineer disabled the local area connection yesterday, when it was on it had limited and he thought that could be the problem but nothings changed since he left Edited January 15, 2022 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Annabella Posted January 15, 2022 Share Posted January 15, 2022 4 minutes ago, Dnk said: yes its disabled, i just did it the BT engineer disabled the local area connection yesterday, when it was on it had limited and he thought that could be the problem but nothings changed since he left Now it's disabled and on ethernet run the ping test again. Record it, and if the same it's router or outside, can't be anything else, if you're having the same problems on multiple devices and on on Wifi and Wired. 1 Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 (edited) Here's a screenshot of the ping test that is running now Edited January 15, 2022 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Annabella Posted January 15, 2022 Share Posted January 15, 2022 Need to try a different router. 1 Link to comment Share on other sites More sharing options...
pf85 Posted January 15, 2022 Share Posted January 15, 2022 You could try factory resetting the router and see if that makes any change but otherwise you'd need to get BT to change the router for a new one 1 Link to comment Share on other sites More sharing options...
Dnk Posted January 15, 2022 Author Share Posted January 15, 2022 Thanks guys, just sending my contact at BT a message and see if they can send me a new Router Link to comment Share on other sites More sharing options...
