Chingy Posted January 9, 2022 Share Posted January 9, 2022 Evening… can anyone tell me the wiring colours for this mirror. Trying to test on the bench to confirm folds etc Thanks in advance Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 9, 2022 Share Posted January 9, 2022 I guess it depends what state you are starting in (open vs closed) But essentially you want to give 12v to Orange whilst grounding Green for motor to move one direction. Then do Orange to Ground, 12v to Green to move motor the other direction. Link to comment Share on other sites More sharing options...
Chingy Posted January 9, 2022 Author Share Posted January 9, 2022 19 minutes ago, Mike2JZ said: I guess it depends what state you are starting in (open vs closed) But essentially you want to give 12v to Orange whilst grounding Green for motor to move one direction. Then do Orange to Ground, 12v to Green to move motor the other direction. Thanks Mike much appreciated, starting in the closed position but all noted and understood Link to comment Share on other sites More sharing options...
Samurai 20V Posted January 11, 2022 Share Posted January 11, 2022 Hi Chingy. I just did this exact test on a set of spare mirrors I had 2 weeks ago. The wiring diagram posted by Mike is the vehicle side. On the mirror itself you need the pink & orange wire. See pic of the mirror I had stripped down.. The test you will do the same way Mike described. FYI, on the mirrors I have, 1 has a good motor, I am getting all the components changed on the PCB, so should be working soon. The 1 with the bad motor, trying to match the motor & replace the components on the PCB. Link to comment Share on other sites More sharing options...
mwilkinson Posted January 11, 2022 Share Posted January 11, 2022 1 hour ago, Samurai 20V said: Hi Chingy. I just did this exact test on a set of spare mirrors I had 2 weeks ago. The wiring diagram posted by Mike is the vehicle side. On the mirror itself you need the pink & orange wire. See pic of the mirror I had stripped down.. The test you will do the same way Mike described. FYI, on the mirrors I have, 1 has a good motor, I am getting all the components changed on the PCB, so should be working soon. The 1 with the bad motor, trying to match the motor & replace the components on the PCB. Any chance you could document the refurb of the motor and PCB for prosterity? At the very least any close up images of the PCB would be great. Link to comment Share on other sites More sharing options...
Chingy Posted January 11, 2022 Author Share Posted January 11, 2022 2 hours ago, Samurai 20V said: Hi Chingy. I just did this exact test on a set of spare mirrors I had 2 weeks ago. The wiring diagram posted by Mike is the vehicle side. On the mirror itself you need the pink & orange wire. See pic of the mirror I had stripped down.. The test you will do the same way Mike described. FYI, on the mirrors I have, 1 has a good motor, I am getting all the components changed on the PCB, so should be working soon. The 1 with the bad motor, trying to match the motor & replace the components on the PCB. Many thank for this and the detail, much appreciated 1 Link to comment Share on other sites More sharing options...
Samurai 20V Posted January 11, 2022 Share Posted January 11, 2022 1 hour ago, mwilkinson said: Any chance you could document the refurb of the motor and PCB for prosterity? At the very least any close up images of the PCB would be great. Will do so… 1 Link to comment Share on other sites More sharing options...
