Dave Posted December 21, 2021 Share Posted December 21, 2021 What’s your thoughts on using this as opposed to premium,the price of petrol has soared and with the current crisis funds are short ,so safe to use or can I mix it with premium or stick to premium ? Quote Link to comment Share on other sites More sharing options...
Annabella Posted December 22, 2021 Share Posted December 22, 2021 Sticking to Shell vmax or Tesco super Quote Link to comment Share on other sites More sharing options...
Style Posted December 22, 2021 Share Posted December 22, 2021 Esso also have 99 as well now But yeah, stick to premium, especially if you've got a JDM car Quote Link to comment Share on other sites More sharing options...
The Raven Posted December 22, 2021 Share Posted December 22, 2021 Seeing the value of these cars now? A few extra pence per litre is a no brainier. Since i put my TT lump in ive only ever ran Tesco or shell. Back when it was a N/A and you couldnt give those engines away i probably would have attempted to run it on chip fat. Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 22, 2021 Share Posted December 22, 2021 If you're struggling to afford petrol, a Supra is not the car for you. Quote Link to comment Share on other sites More sharing options...
mc92 Posted December 22, 2021 Share Posted December 22, 2021 I use it in my NA sometimes, it doesn't run any different than it does on 99 and doesn't get any better MPG (I've recorded mpg a bunch of times and it's 21 regardless of fuel). Probably more important for turbo cars as others have said. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 22, 2021 Share Posted December 22, 2021 I think the OP is more concerned if its safe to use the higher ethanol content fuel, rather than any running cost aspect, am I right? Answer- you'll be fine. Quote Link to comment Share on other sites More sharing options...
Dave Posted December 24, 2021 Author Share Posted December 24, 2021 On 12/22/2021 at 10:35 AM, Simon_RD said: I know its expensive, but I'd run super unleaded sorry. I've found Tesco 99 Momentum has worked best for me. I see it as just part and parcel of owning a high performance car. With that said, I've have always wondered about the cost efficiency of Regular E10 v Super unleaded, I just haven't seen any actual studies on it. E10 Will have a lower MPG, but is cheaper, while Super Unleaded will have a Higher MPG but is more expensive. So there is an offset. For a daily driven, boring, ordinary, modern car, the E10 has to be more cost efficient, i.e lower cost per mile. But for higher performance cars, Its hard to tell, as most are designed for higher RON. E.g - In the 1995 owners manual for our cars(GTE), its listed as needing 96 or higher. (RON, Not MON). So e10(which is only 95 MOL) Isn't recommended for our cars as result, regardless of the ethanol component. It would be interesting to see the difference in long term costs of running E10 against Say Tesco momentum 99 in a 2jz-gte. The lower MPG and poorer performance of the E10 could mean any long term price difference might not be that substantial ... but that is admittedly a massive guess. Although I sure as hell wont be doing the testing. Not only is it not recommended, but I've run 95 RON a couple of times in emergencies and I felt it was noticeably ******* terrible. Yeah think I’ll stick to super cheers for explaining Quote Link to comment Share on other sites More sharing options...
Dave Posted December 24, 2021 Author Share Posted December 24, 2021 On 12/22/2021 at 8:47 AM, Thorin said: If you're struggling to afford petrol, a Supra is not the car for you. Yes after all I’ve had it since 2004 maybe it’s not Quote Link to comment Share on other sites More sharing options...
Dave Posted December 24, 2021 Author Share Posted December 24, 2021 On 12/22/2021 at 4:53 PM, mc92 said: I use it in my NA sometimes, it doesn't run any different than it does on 99 and doesn't get any better MPG (I've recorded mpg a bunch of times and it's 21 regardless of fuel). Probably more important for turbo cars as others have said. Thanks Quote Link to comment Share on other sites More sharing options...
