Mzemzu Posted December 3, 2021 Share Posted December 3, 2021 Hi guys, I'm unable to source a TSRM for the JDM 2JZGTE vvti timing belt installation. Possible links on this website have expired. Both camshaft pulleys have two markings: a dot and when turning the camshaft clockwise a line will appear. When referenced to the two notches on the No 4 timing plate cover, which marking is used for top dead center for No 1 cylinder? Direction of crankshaft is clockwise. If anyone can source the relevant page(s) even if in Japanese I can get it translated. Thanks... Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 3, 2021 Share Posted December 3, 2021 1) Put crank at TDC. I normally do this by aligning the timing belt crank sprocket line marking with the circle dot on the oil pump. Same as you would on non Vvti. 2) on Vvti pulley rotate the pulley fully counter clockwise so it’s in its fully relaxed state, then align the line marking with upper timing cover marking. 3) on exhaust pulley align line mark with upper timing cover marking 4) install belt as normal 1 Quote Link to comment Share on other sites More sharing options...
