Steve W Posted May 12, 2003 Share Posted May 12, 2003 Phil's already basically asked this question in another thread... BUT, who actually HAS/had 275/40-17's or 285/40-17's on Std. UK Toyota wheels ? ? AND, just to be cheeky, anybody GOT/can take photo to show how they 'sit' on the wheels.... ie. how well they match the rim / how much they 'stick-out' (if that makes sense ? ?) FatS. Quote Link to comment Share on other sites More sharing options...
Thorin Posted May 12, 2003 Share Posted May 12, 2003 285 is too wide for the stock 17" rears. Quote Link to comment Share on other sites More sharing options...
Steve W Posted May 12, 2003 Author Share Posted May 12, 2003 YEAH, I know it is.... in theory ! BUT, I'm almost positive someone (or two) on here had 285's on their 17's ? ? ? Quote Link to comment Share on other sites More sharing options...
Thorin Posted May 12, 2003 Share Posted May 12, 2003 Originally posted by Steve W YEAH, I know it is.... in theory ! BUT, I'm almost positive someone (or two) on here had 285's on their 17's ? ? ? Then they need a Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted May 12, 2003 Share Posted May 12, 2003 I run 275/35x17, but not on standard rims. Quote Link to comment Share on other sites More sharing options...
GavinL Posted May 13, 2003 Share Posted May 13, 2003 I run 275's on standard rims. I can't oblige you with a picture but with SO2's the sidewalls are just a little wider than the rim itself. Alex H had 285 rears on a 9.5 rim a while back Quote Link to comment Share on other sites More sharing options...
Sharpie Posted May 13, 2003 Share Posted May 13, 2003 Do you feel the difference ? Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 13, 2003 Share Posted May 13, 2003 Originally posted by John Packham I run 275/35x17, but not on standard rims. John what rim widths are your rears? Quote Link to comment Share on other sites More sharing options...
GavinL Posted May 13, 2003 Share Posted May 13, 2003 Originally posted by Peter Sharp Do you feel the difference ? Yes but that was in conjuction with a jump from F1's to S02's at the same time so that's not really very fair. I would imagine that going up one or two sizes in the same make/model of tyre is the only fair assessment. Does someone want to do a little RLTC data logging as an experiment? Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted May 13, 2003 Share Posted May 13, 2003 Originally posted by Steve W who actually HAS/had 275/40-17's on Std. UK Toyota wheels ? ? Me, on the NA, S-02s, no pic, but a nice fit. Quote Link to comment Share on other sites More sharing options...
Sharpie Posted May 13, 2003 Share Posted May 13, 2003 Originally posted by GavinL Yes but that was in conjuction with a jump from F1's to S02's at the same time so that's not really very fair. Good enough for me as I will be going from Yoko AVS Sport to S02's (If I can get them - NOT) so, S03's when I get through the AVS's. Thanks for the feedback. Quote Link to comment Share on other sites More sharing options...
Steve W Posted May 13, 2003 Author Share Posted May 13, 2003 ALRIGHT... just tp please Thorin ! ! ! ( ) AND, just in case the little 'Excel' tables of FIT-for-RIM-width are correct ! ! I'll get 275's NOT 285's....... SO, I'm going 275/40-17's......... Quote Link to comment Share on other sites More sharing options...
GavinL Posted May 13, 2003 Share Posted May 13, 2003 Originally posted by Peter Sharp Good enough for me as I will be going from Yoko AVS Sport to S02's (If I can get them - NOT) so, S03's when I get through the AVS's. Thanks for the feedback. If you find a source for 275 SO2's give me a shout Quote Link to comment Share on other sites More sharing options...
Sharpie Posted May 13, 2003 Share Posted May 13, 2003 Will do - I still have a good depth at the mo. Quote Link to comment Share on other sites More sharing options...
Steve W Posted May 17, 2003 Author Share Posted May 17, 2003 Now have 285/40-17's on me stock rims...... YES, they look like they MAY end up touching the inner-arch-edge ????? BUT, I'll have to wait and see (haven't yet, but it's when it's loaded /Pod etc that it might) I went for the Khumo 712's (Ecsta Supras) as they are MUCH cheaper then the next nearest..... which were the F1 GSD3's !? (but in 255's) also had the entire 'set-up' checked and adjusted, front and back fronts were almost spot on anyway, but rears were WAY out on toe and camber..... I'll report back on wear/handling/RUBBING/Pod-a-bility when ever anything becomes apparent (and it'll be the TRUTH, not optimism ) FatS. Quote Link to comment Share on other sites More sharing options...
