Dave Posted November 25, 2021 Share Posted November 25, 2021 I want to replace the rubber intake pipe on my Na with a chrome pipe where’s the best place to buy the pipe and the silicon tubes ,thanks Link to comment Share on other sites More sharing options...
evinX Posted November 29, 2021 Share Posted November 29, 2021 Silicone peice you can get from Stoney racing in the UK for thr 2JZ GE. The metal part, id also like to know. What diameter, what degree bend. And most important it must have a pipe welded to it for the crank case hose to dump into the intake like oem. Unless theres some type of screw in pipe/ grommet so we can tap into the metal pipe to hold the small crank case pipe without welding. Link to comment Share on other sites More sharing options...
Dave Posted December 2, 2021 Author Share Posted December 2, 2021 Thanks evin ,don’t think it’s a 90 degree bend so will wait for someone to answer Link to comment Share on other sites More sharing options...
evinX Posted December 19, 2021 Share Posted December 19, 2021 (edited) So i came across this 1jz intake. The AN fitting on the pipe would do the job for the outlet for the valve cover hose to connect to. But dont know what type of an fitting it is, threaded etc? Edited December 19, 2021 by evinX (see edit history) Link to comment Share on other sites More sharing options...
Herb Posted December 19, 2021 Share Posted December 19, 2021 (edited) I had one custom made for my intake. It is made from aluminium and ceramic coated to help against heat soak. As stated above it is not a 90 degree bend, both hose connections are welded in. Edited December 19, 2021 by Herb (see edit history) 2 Link to comment Share on other sites More sharing options...
Tyson Posted December 19, 2021 Share Posted December 19, 2021 How clean is that bay! Damn 1 Link to comment Share on other sites More sharing options...
Herb Posted December 19, 2021 Share Posted December 19, 2021 2 hours ago, Tyson said: How clean is that bay! Damn Thanks Link to comment Share on other sites More sharing options...
evinX Posted December 19, 2021 Share Posted December 19, 2021 6 hours ago, Herb said: I had one custom made for my intake. It is made from aluminium and ceramic coated to help against heat soak. As stated above it is not a 90 degree bend, both hose connections are welded in. Im liking that carbon far shroud, is it a TT shroud or NA? Link to comment Share on other sites More sharing options...
evinX Posted December 20, 2021 Share Posted December 20, 2021 So i was looking at these hose barbs. If i could get the elbow pipe to replace the oem plastic peice i could drill and tap a hole to thread the barb into for the valve cover pipe to clip onto Link to comment Share on other sites More sharing options...
Herb Posted December 20, 2021 Share Posted December 20, 2021 On 12/19/2021 at 4:33 PM, evinX said: Im liking that carbon far shroud, is it a TT shroud or NA? It is a TT fan shroud made entirely from carbon fibre. It is compatible with the NA viscous fan in my case. It has also got the additional (smaller) hole for the little auxiliary fan. I retrofitted the whole electric aux fan from a TT US Spec car recently to make use of that hole. Link to comment Share on other sites More sharing options...
Dave Posted December 21, 2021 Author Share Posted December 21, 2021 On 12/19/2021 at 9:10 AM, Herb said: I had one custom made for my intake. It is made from aluminium and ceramic coated to help against heat soak. As stated above it is not a 90 degree bend, both hose connections are welded in. Love the radcover where did you get it Link to comment Share on other sites More sharing options...
Dave Posted December 21, 2021 Author Share Posted December 21, 2021 On 12/19/2021 at 9:10 AM, Herb said: I had one custom made for my intake. It is made from aluminium and ceramic coated to help against heat soak. As stated above it is not a 90 degree bend, both hose connections are welded in. Love the fan shroud and where did you get the exhaust manifold that’s not oem Link to comment Share on other sites More sharing options...
Dave Posted December 21, 2021 Author Share Posted December 21, 2021 Found this on eBay https://www.ebay.co.uk/itm/275061625213?hash=item400af3517d:g:ffAAAOSwq0xgkSAy Link to comment Share on other sites More sharing options...
Herb Posted December 23, 2021 Share Posted December 23, 2021 On 12/22/2021 at 12:33 AM, Dave said: Love the radcover where did you get it Paul @ Garage Whifbitz https://www.garagewhifbitz.co.uk/toyota/supra/whifbitz-carbon/garage-whifbitz-supra-carbon-cooling-panel.html Link to comment Share on other sites More sharing options...
Herb Posted December 23, 2021 Share Posted December 23, 2021 On 12/22/2021 at 12:38 AM, Dave said: Love the fan shroud and where did you get the exhaust manifold that’s not oem The exhaust manifold is a one off custom made and covered with heat shielding. The same stuff they use in motorsports. Link to comment Share on other sites More sharing options...
