jaymdee Posted November 24, 2021 Share Posted November 24, 2021 Driving home tonight and suddenly had the battery warning light, engine oil, engine heat (?) and hazard warning lights all come on. Stopped and restarted and still the same so drove home 5 mins figuring it’s the alternator. Battery down to 11.8 volts. Should have tested it before I turned it off. have seen posts suggesting to check earths (where, how?) before buying a new alternator. Getting a lift to work tomorrow but will try a few tests on Friday. So where’s best for an alternator for TT auto? cheers Jon Link to comment Share on other sites More sharing options...
AC93 Posted November 24, 2021 Share Posted November 24, 2021 Get a new one from SRD or Keron, takes 5mins to swap out 1 Link to comment Share on other sites More sharing options...
baldy Posted November 26, 2021 Share Posted November 26, 2021 (edited) DC power make some real nice alternators Edited November 28, 2021 by baldy (see edit history) Link to comment Share on other sites More sharing options...
Mugello Posted November 27, 2021 Share Posted November 27, 2021 Upgraded unit from SRD with options on the finish too! Link to comment Share on other sites More sharing options...
mattdavies Posted November 29, 2021 Share Posted November 29, 2021 SRD probably have one on the shelf and will do you an exchange. IT takes 30 mins to swap them so you could be running again by the weekend Link to comment Share on other sites More sharing options...
TuneR Posted November 30, 2021 Share Posted November 30, 2021 GS300 fits too and might be more readily available... Link to comment Share on other sites More sharing options...
Ark Posted December 1, 2021 Share Posted December 1, 2021 Hello Jon, long time. Similar happened to me last year - battery just wouldn't hold a charge, voltage when running was down in the 11s. When I took the alternator off it was badly corroded, casing cracked... Got a brand new alternator from the local alternator guy for about £200 (I forget exactly), worked a treat. No need for the expensive shiny-shiny if you just want it functional. This guy, if you want to give him a try. https://www.jasm.co.uk/ Link to comment Share on other sites More sharing options...
jaymdee Posted January 3, 2022 Author Share Posted January 3, 2022 Cheers people. Still not managed to get this sorted yet but some good tips. Hi Chris. Good to hear from you. Hope you guys are doing well. Link to comment Share on other sites More sharing options...
