Leaking Shock Absorber - Options?
J-Meiser
Hi everyone,
As you can see from the title, one of my shock absorbers has started leaking 😞 and I'm basically looking for input on what to do next.
I have already reached out to Keron and I am awaiting a response as to whether he has any in stock. In case he is unable to help out this time around, what would you all recommend? I am currently considering the following:
1. Getting all of my shock absorbers examined and repaired/refurbished so that I can avoid any more surprises. Then fit lowering springs. A friend of mine at work recommended this company: https://www.corneringforce.com/ - has anyone ever used them or heard of them before?
2. Replace existing shock absorbers and springs with coilovers. Any recommendations?
I have never found the stock setup uncomfortable, as I used my Supra as my daily before the pandemic kicked in, so I do not want to compromise the comfort but lowering my Supra was on my "To-Do" list anyway; I recently bought Big Supe's Tein Springs to do just that. My Supra has KYB shock absorbers on all corners; I honestly do not know whether they are factory fit or not, but they have been on my Supra ever since I bought it.
Any input or advice would be greatly appreciated!
I purchased new Bilstein set from Toyota as part of my suspension renewal. So you could start off by asking Toyota.
You would likely find the cheapest option is to buy a set oil coilovers and sell the OEM springs you have to offset the cost as they are discontinued and therefore have some value.
  • Like 1
I would recommend getting a set of Bilstein B6's (I'm not sure how much they differ from the OE Bilstein's Rider mentioned) to pair with your lowering springs. I have a set with Eibach lowering springs and they're great. I'm not sure who sells them the cheapest (my set was used) but I think they'll set you back around £130 a shock.
I'd recommend getting a new set of dust boots at the same time too (top mounts probably aren't necessary as the dust boot is the rubber isolator for the top mounts).
  • Like 1
This ☝️☝️
  • Like 2
Thank you all very much for your input!
It has actually made me think hard about a part of my post - I used to drive my Supra as my daily, but that was when I was travelling to work 5 days a week. That is not the case any more and to be honest, that could become even less frequent, so could firm things up, just a little bit.
I will check out prices for the Bilsteins and weigh them up against the KYBs and stocks, then go from there. What are the Bilsteins like compared to stock?
I have ordered some new dust boots/insulators for the front 👍🏾. I already have new a new set on the rear as I supplied them when I had the springs replaced, so I will transfer them over to the new setup, whatever I go with. They are yet to cover 50 miles, so they are still virtually brand new!
  • Like 1
The Bilsteins are definitely stiffer than the OE KYB's etc., but likely some of variance in stiffness also comes from replacing 20+y/o tired shocks with new ones.
I use the Bilstein equipped car 'daily' (still WFH most days now 😑), and although stiffer, I have never felt that they're too stiff.
Even if you aren't a fan of them once installed, I'm sure they'll sell quickly if you wanted to revert back to stock (I may even be interested in a nearly new set!)
  • Like 1
Sounds fair, thank you for all of the info!
I am currently evaluating my options and seeing what is available, so we will see what happens.
A recommendation was made to me to contact @Chris Wilson about his suspension setup, but it would appear that he is unable to receive messages, so if you see this Chris and are able to get in touch, I would be very grateful!
  • Like 1
You need to email him or ring him, his email is in his sig
  • Like 1
There is a serious delay in getting new Bilsteins at the moment, I have several sets on order from months ago. I may have good used ones and some good used stock none Bilsteins, ring me on 07971-952084 if possible, or e-mail me please at  [email protected]   And thanks Annabella
