SilverMachine Posted November 17, 2021 Share Posted November 17, 2021 I recently bought a replacement rad after turning up for work like a steam train the other morning. Once fitted and filled, I ran the car up to temp and took it around the block to release any trapped air in the system. Within a minute I had steam gushing out of the top of the rad. After several hours, I went back to the car, took the cap off the rad and turned the key. The water gushed up and out of the rad like a 6ft fountain. Not sure why this happens now. I hope I haven't blown the head. No water in the oil. I have changed the thermostat thinking it was cooked. Any help would be grateful. Thanks, Gaz Link to comment Share on other sites More sharing options...
evinX Posted November 17, 2021 Share Posted November 17, 2021 (edited) Take the thermostat out and see if its stuck using 1 boiling cup of water and 1 cup of cold water. I THINK tbe hot water will open it and the cold will close it. Edit, seen you did the thermostat. Did you fit it the right way around? Edited November 17, 2021 by evinX (see edit history) Link to comment Share on other sites More sharing options...
SilverMachine Posted November 17, 2021 Author Share Posted November 17, 2021 Just now, evinX said: Take the thermostat out and see if its stuck using 1 boiling cup of water and 1 cup of cold water. I THINK tbe hot water will open it and the cold will close it. Thanks evinX, I removed the brand new thermostat from the housing and 'doctored' the old one (took the guts out of it, just leaving the seal) and put this in. Still did the same thing. When I turned the key before, it would idle normally with bubbles and whisps of steam from the top of the rad. Now it's a torrent of water straight up! Link to comment Share on other sites More sharing options...
evinX Posted November 17, 2021 Share Posted November 17, 2021 1 minute ago, SilverMachine said: Thanks evinX, I removed the brand new thermostat from the housing and 'doctored' the old one (took the guts out of it, just leaving the seal) and put this in. Still did the same thing. When I turned the key before, it would idle normally with bubbles and whisps of steam from the top of the rad. Now it's a torrent of water straight up! Honestly never heard of those symptoms before mate. Even with head gaskets going. Seems lile somethings blocked...really a scratch head moment this one is. Any ideas through the night and ill post back Link to comment Share on other sites More sharing options...
SilverMachine Posted November 17, 2021 Author Share Posted November 17, 2021 3 minutes ago, evinX said: Honestly never heard of those symptoms before mate. Even with head gaskets going. Seems lile somethings blocked...really a scratch head moment this one is. Any ideas through the night and ill post back Thanks. It's got me baffled too, that's why I've come on here to the 'font of knowledge' Link to comment Share on other sites More sharing options...
evinX Posted November 17, 2021 Share Posted November 17, 2021 (edited) If anyone has seen it before its probably Keron, hes the go to man when it comes to...'please help me' Worth giving him a call Edited November 17, 2021 by evinX (see edit history) Link to comment Share on other sites More sharing options...
SilverMachine Posted November 17, 2021 Author Share Posted November 17, 2021 25 minutes ago, evinX said: If anyone has seen it before its probably Keron, hes the go to man when it comes to...'please help me' Worth giving him a call Yes he is. Top bloke. Already spoken to him earlier. He says just keep flushing the system 3-4 times to see if this sorts it. Thought I'd see if anyone else on here had a similar issue. 1 Link to comment Share on other sites More sharing options...
Swampy442 Posted November 17, 2021 Share Posted November 17, 2021 Get the front right up in the air, fill the rad, run the engine with the cap off and let it burp itself 1 Link to comment Share on other sites More sharing options...
SilverMachine Posted November 17, 2021 Author Share Posted November 17, 2021 45 minutes ago, Swampy442 said: Get the front right up in the air, fill the rad, run the engine with the cap off and let it burp itself Thanks Swampy442. I'll give that a whirl once I get it back home. Thanks Gaz Link to comment Share on other sites More sharing options...
