Big Supes Posted November 3, 2021 Share Posted November 3, 2021 Sorry if this has been discussed a million times. I found old threads on the subject, but all the links to soundbites and videos had expired. When considering my single build for next year I really want to get the sound right and need the help of those who have been through different exhausts, manifolds and turbos to steer me in the right direction for what I'm after. I'd like to get as close as possible to the older set ups people used to run. The deeper burble, chewbacca sound like the Greddy Power Extreme in the video attached. I know the turbo and manifold have quite a big effect on this too and I'd imagine the better flowing/newer manifolds probably decrease that unequal length chewbacca noise. There used to be a video of Dude's old silver auto that ran a T88 playing on an airstrip with other jap cars for a top speed challenge. It sounded immense. Link to comment Share on other sites More sharing options...
Swampy442 Posted November 3, 2021 Share Posted November 3, 2021 Cams also have a lot to do with the sound. If you can find one, the RS-R exhaust makes a nice noise Link to comment Share on other sites More sharing options...
Big Supes Posted November 4, 2021 Author Share Posted November 4, 2021 8 hours ago, Swampy442 said: Cams also have a lot to do with the sound. If you can find one, the RS-R exhaust makes a nice noise Yeah, that's true, but I find cams give more of an engine characteristic that then gets changed by the above. I'll try and find some audio of an RS-R. Link to comment Share on other sites More sharing options...
Burna Posted November 4, 2021 Share Posted November 4, 2021 (edited) HKS manifold, 264 cams, RS*R exhaust... B16F84BB-FC0A-4A01-AE5D-F5F331B046B1.MP4 730D1972-979F-4FC3-B8CF-8969B780F8D9.MP4 Edited November 4, 2021 by Burna (see edit history) 4 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted November 4, 2021 Share Posted November 4, 2021 A cast manifold is where the deep note comes from and the metal the exhaust is made from will influence this too. How you make the exhaust gases resonate is key if you’re looking for a particular sound. Cast manifold = deep sound Tubular manifold = higher pitched sound (reminds me somewhat of F1) If you want a lope at idle you need silly cams which will ruin drivability if they don’t match your power level. Link to comment Share on other sites More sharing options...
Big Supes Posted November 4, 2021 Author Share Posted November 4, 2021 1 hour ago, Frank Bullitt said: A cast manifold is where the deep note comes from and the metal the exhaust is made from will influence this too. How you make the exhaust gases resonate is key if you’re looking for a particular sound. Cast manifold = deep sound Tubular manifold = higher pitched sound (reminds me somewhat of F1) If you want a lope at idle you need silly cams which will ruin drivability if they don’t match your power level. Perfect, thanks for clarifying re the manifold. I was thinking the manifold is going to be crucial to achieving the sound I want. I've been looking at the RPS remake by SP Racing with the F1 manifold. With a large muffler like the greddy PE I think I'll be someway sorted. Stock UK fuel system will be in place until the next step which will be ECU, cams and fuel system. 3 hours ago, Burna said: HKS manifold, 264 cams, RS*R exhaust... B16F84BB-FC0A-4A01-AE5D-F5F331B046B1.MP4 730D1972-979F-4FC3-B8CF-8969B780F8D9.MP4 Sounds awesome Burna. Would like to hear more of it off the dyno. Link to comment Share on other sites More sharing options...
