mwilkinson Posted February 13, 2022 Share Posted February 13, 2022 Looking forward to seeing the seats post refurb. I don't think I've ever seen any OEM recaros subject to more than a bolster repair. I did the lower bolsters on my car, but the upper ones aren't available so would need to be custom work. I can see that the bolster repair you refer to is a lower one, but I'm intruged to see the result of any custom upper bolster repair you might need. May I ask where you found the correct or matching material for the seats? Link to comment Share on other sites More sharing options...
Chingy Posted February 13, 2022 Author Share Posted February 13, 2022 7 hours ago, Hammer said: Great build and really enjoying the thread, great work with both. Lovely supra. Looking forward to seeing the end result, well done. Thanks mate, much appreciated. Team at SRD doing a great job of project managing it 5 hours ago, mwilkinson said: Looking forward to seeing the seats post refurb. I don't think I've ever seen any OEM recaros subject to more than a bolster repair. I did the lower bolsters on my car, but the upper ones aren't available so would need to be custom work. I can see that the bolster repair you refer to is a lower one, but I'm intruged to see the result of any custom upper bolster repair you might need. May I ask where you found the correct or matching material for the seats? Yes trying to go the extra mile for this build, should be good. Phil is a master of his craft. Material was sourced from Australia... Phil had contacted Recaro here in the UK but one of the materials discontinued the other out if stick with no eta 2 Link to comment Share on other sites More sharing options...
Chingy Posted February 15, 2022 Author Share Posted February 15, 2022 Some of the more difficult parts starting get sourced…Thank you to Roger for the airbox set up & Nash for the IC set up 3 Link to comment Share on other sites More sharing options...
Chingy Posted February 17, 2022 Author Share Posted February 17, 2022 (edited) Looking to source genuine Toyota parts…. SRD are one of the most comprehensive stockists & suppliers of Supra parts. Send Lee an email for better than main dealer knowledge, availability & prices… [email protected] Edited February 17, 2022 by Chingy (see edit history) 4 Link to comment Share on other sites More sharing options...
Chingy Posted February 19, 2022 Author Share Posted February 19, 2022 (edited) Fresh OEM bonnet & Spoiler on the car, the standard great workmanship by Baldy And a huge thank you to Shane for the VVTI air box & your hospitality today Edited February 19, 2022 by Chingy I Can’t spell (see edit history) 5 Link to comment Share on other sites More sharing options...
Chingy Posted March 9, 2022 Author Share Posted March 9, 2022 When SRD say nut & bolt Heritage Build… that’s not any old nut & bolt. Level of details is second to none. 3 Link to comment Share on other sites More sharing options...
Dieter Posted March 9, 2022 Share Posted March 9, 2022 Awesome, where did you buy all these parts and Lexus parts also there at....., great project, good luck Link to comment Share on other sites More sharing options...
Chingy Posted March 10, 2022 Author Share Posted March 10, 2022 21 hours ago, Dieter said: Awesome, where did you buy all these parts and Lexus parts also there at....., great project, good luck Much appreciated If it’s available...SRD Tuning stock or can source https://www.srdtuning.com 1 Link to comment Share on other sites More sharing options...
Dieter Posted March 11, 2022 Share Posted March 11, 2022 Hi, hello, great , thanks for the link and I have for example bought my Cooling Panel at Paul from Garage WifBitz, am there with very, very satisfied 1 Link to comment Share on other sites More sharing options...
Dieter Posted March 11, 2022 Share Posted March 11, 2022 10 hours ago, Chingy said: Sehr geschätzt Wenn es verfügbar ist ... SRD Tuning Stock oder kann https://www.srdtuning.com beziehen I have in the store this tarp , but very, very expensive, also have this tarp , but for 80 euros and it is in excellent quality https://www.srdtuning.com/product/coverzone-kalahari-fleece-car-cover-a80-supra/ Link to comment Share on other sites More sharing options...
Chingy Posted March 17, 2022 Author Share Posted March 17, 2022 SRD Heritage Services.. winding back 21yrs, stripped, cleaned, vapour blasted, cleaned & repeat. Devils in the detail with these guys. 4 Link to comment Share on other sites More sharing options...
Dieter Posted March 17, 2022 Share Posted March 17, 2022 2 hours ago, Chingy said: SRD Heritage Services.. 21 Jahre zurückgezogen, zerlegt, gereinigt, dampfgestrahlt, gereinigt und wiederholt. Bei diesen Jungs steckt der Teufel im Detail. Awesome, very good work and have they done that without glass bead blasting, or sandblasting 1 Link to comment Share on other sites More sharing options...
Dieter Posted March 17, 2022 Share Posted March 17, 2022 2 hours ago, Chingy said: SRD Heritage Services.. 21 Jahre zurückgezogen, zerlegt, gereinigt, dampfgestrahlt, gereinigt und wiederholt. Bei diesen Jungs steckt der Teufel im Detail. You own 2 Supras, right ? 1 Link to comment Share on other sites More sharing options...
Dieter Posted March 17, 2022 Share Posted March 17, 2022 oh, I have to tell you something else, if you want to buy the Car Cover, you have to take absolutely size XL, because of our OEM rear spoiler 1 Link to comment Share on other sites More sharing options...
Chingy Posted March 17, 2022 Author Share Posted March 17, 2022 4 hours ago, Dieter said: Awesome, very good work and have they done that without glass bead blasting, or sandblasting SRD use Vapor blasting it is a surface refinishing process used to clean and restore surfaces. Instead of dry abrasive media (used in sandblasting), it uses a combination of water, compressed air, detergents with finer and gentler media to remove oxidized metal and corrosion. 3 hours ago, Dieter said: oh, I have to tell you something else, if you want to buy the Car Cover, you have to take absolutely size XL, because of our OEM rear spoiler 4 hours ago, Dieter said: You own 2 Supras, right ? Yes very fortunate to have two… just need a bigger garage now 3 Link to comment Share on other sites More sharing options...
Dieter Posted March 17, 2022 Share Posted March 17, 2022 5 hours ago, Chingy said: Verwendung von SRD Dampfstrahlen ist ein Verfahren zur Oberflächennachbearbeitung, das zum Reinigen und Wiederherstellen von Oberflächen verwendet wird. Anstelle trockener Schleifmittel (wie beim Sandstrahlen) verwendet es eine Kombination aus Wasser, Druckluft, Reinigungsmitteln mit feineren und sanfteren Mitteln, um oxidiertes Metall und Korrosion zu entfernen. Ja, sehr glücklich, zwei zu haben ... brauche jetzt nur eine größere Garage Top 1 Link to comment Share on other sites More sharing options...
Chingy Posted March 21, 2022 Author Share Posted March 21, 2022 Few more OEM bits from SRD 1 Link to comment Share on other sites More sharing options...
Dieter Posted March 21, 2022 Share Posted March 21, 2022 Very, very nice, you investts really good and it will all look like new later, whatt have you paid for the valve covers lid and where bought, if I may ask? On the weekend I still installed the new window trim right door and new window is also already inside, now still left side new window, I already have the moldings, dashboard is also completely OEM repainted ( do you want to see pictures of the dash ? ) Translated with www.DeepL.com/Translator (free version) Link to comment Share on other sites More sharing options...
Wishieftrottle Posted March 22, 2022 Share Posted March 22, 2022 Very nice stuff Chingy! Do you think that T changed the color of cover? It looks like mine from 1997 is more greenish and new one is pretty blue anyway, always looking forward for new updates from you 1 Link to comment Share on other sites More sharing options...
Dieter Posted March 22, 2022 Share Posted March 22, 2022 5 minutes ago, Wishieftrottle said: Sehr schönes Ding Chingy! Glauben Sie, dass T die Farbe der Abdeckung geändert hat? Es sieht so aus, als wäre meins von 1997 eher grünlich und das neue sowieso ziemlich blau, ich freue mich immer auf neue Updates von Ihnen So I definitely like the new cover better and what did you pay for the Valve Cover and where did you buy it ? Link to comment Share on other sites More sharing options...
Chingy Posted March 22, 2022 Author Share Posted March 22, 2022 3 hours ago, Wishieftrottle said: Very nice stuff Chingy! Do you think that T changed the color of cover? It looks like mine from 1997 is more greenish and new one is pretty blue anyway, always looking forward for new updates from you Thanks buddy. Quite satisfying to see SRD put it back to showroom new condition with all the new parts they keep sourcing. Colour wise, it’s definitely brighter probably being fresh paint and not faded with heat etc but think the colour is the same, think my old iPhone camera playing tricks Link to comment Share on other sites More sharing options...
Chingy Posted March 22, 2022 Author Share Posted March 22, 2022 3 hours ago, Dieter said: So I definitely like the new cover better and what did you pay for the Valve Cover and where did you buy it ? Many thanks, all parts sourced through Lee @ SRD who are project managing the build under their new Heritage stage services Link to comment Share on other sites More sharing options...
gabby rox Posted March 22, 2022 Share Posted March 22, 2022 looks like you're doing great job so far ! I enjoyed the thread 1 Link to comment Share on other sites More sharing options...
Chingy Posted March 22, 2022 Author Share Posted March 22, 2022 1 hour ago, gabby rox said: looks like you're doing great job so far ! I enjoyed the thread will keep the updates coming Link to comment Share on other sites More sharing options...
Dieter Posted March 22, 2022 Share Posted March 22, 2022 2 hours ago, Chingy said: wird die Updates kommen lassen that works you will see and please report the result 1 Link to comment Share on other sites More sharing options...
