tayr Posted October 18, 2021 Share Posted October 18, 2021 Hi All, Put my doors back on after a respray and plugged everything in, now the drivers side window won't go up or down. The passenger side on the same switch works fine. I am not sure which wire it is but there is no obvious pinching or fraying, and it worked fine before the doors came off. There are a couple small speaker wires i think that i haven't plugged back in, mainly because i'm not sure which goes to what yet but i don't think that would effect anything? Anybody had similar? I tried a new switch and still the same, passenger window fine, drivers one not. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted October 18, 2021 Share Posted October 18, 2021 Try a voltmeter on the switch to rule that out. You can do the same on the feed from the plug. All earths grounded? Fuses checked? All plug connections okay on the male and female side? Sounds daft I know but sometimes it’s the simplest of things. Link to comment Share on other sites More sharing options...
