NA-T parts + 2JZ-GE parts
Josh42
All,
I have the following items for sale;
- Used Garage Whifbitz T4 NA-T log manifold for the 2JZ-GE.
No cracks or previous repairs.
45mm wastegate flange.
Ran at 510 flywheel horsepower for a number of years.
£250 + postage.
- A set of used Siemens DEKA 650cc high impedance 11mm injectors suitable for the 2JZ-GE.
Removed as I’m going for more power.
They are supplied with plug and play harnesses that are compatible with the OEM wiring loom connectors.
Seals appear to be in good condition, with no leaks, however, I would advise new seals for complete peace of mind.
£200 ONO.
- OEM HT leads & distributor cap
These have covered approximate 5000 miles and were purchased new from my local dealership.
They are all in good condition and include the stock cable tidies/brackets.
Includes king lead.
£40 ONO
- 2JZ GE inlet parts as fitted to my NA-T setup.
Included are:
- Throttle body
- Throttle position sensor
- ‘Y’ pipe
- Plenum modified to remove stock ACIS butterfly system
- lower runners (not pictured)
All painted/powder coated gloss black - not a perfect job, but tidy enough.
- Includes new OEM ‘y’ pipe to plenum gaskets
- *DOES NOT* include IACV
£70
