Please help! Fuelling issue at rear in my big single.
adnanshah247
Gentleman,
Thank you for reading. I have a a right pita issue with the suppy.
This is issue the fuelling in the back. I have a brand new walbro 450 in tank connected to a swirl pot that then goes to 2 x Bosch 044 pumps externally to the engine.
1st issue is putting fuel in, the second I put nozzle in the fuel comes running back up and causes the handle to click. It bubbles up the spout immediately.
2nd issue, I have to brim the car slowly for ages right to the top of the spout/filler cap, literally to the point it wants to fall out. The car does 40-50 miles and then I can hear the external Bosch pumps making a lot of noise as if they are not getting any fuel and the car cuts out on me, Jerry can of fuel in and she fires right up then off to the petrol station we’re again she takes only £15-£20 max and is over flowing.
What is going on here? Also worth mention when I go round a long bend I get hesitation from the car as if she wants to break down.
Im running a big single and under boost she’s fine. But this tank is driving me insane. Mechanic and I are stumped so reaching to the geniuses here for help!
7 hours ago, mattdavies said:
Sounds like the fuel tank breather, it may not be the fact your filling it up it may be that you are opening the fuel cap.
How do I dea with this issue?
2 hours ago, Swampy442 said:
First question is - Why do you need 2x 044 pumps? Thats a shit load of fuel, 1 would be plenty. Im saying its fuel starvation, you have a 450lph pump supplying 2 pumps shifting what, 600lph?
The cars over 1k hp. There is a big swirl pot in the back between the 450 and Bosch 044’s.
Has the problem just suddenly appeared? Or is this a new build setup and it's never run right yet?
If it's just started happening I'm inclined to go along with what Matt said, and the breather to the tank is blocked. Which would prevent you putting in fuel like you said, and also from pumping fuel out, and that's why you can hear the 450 pump labouring.
The 450lph to supply the swirl pot and two 044s is going to be more then enough for street use, unless you are WOT for some substantial time I doubt that you will cavitate with fuel, also as soon as you let off the throttle you would be fine again because in 8 secs yoiu would have a litre of fuel back in your swirl pot. the difference in flow between the inlet and the outlet is less the 100ml a second
Have had 3 external people say this to me, how do I go about fixing the breather? Is there a ‘how to guide?’ Please???
Just checked with someone more knowledgeable than me, and he's confirmed that there are two breathers from the petrol tank. One goes to the top of the filler neck, the other to the charcoal canister in the engine bay.
Check both the breathers are clear first, then go from there.
